| 232 | |
| 233 | == Week 7 == |
| 234 | '''1) What did I complete this week?'''\\ |
| 235 | This week was mostly about finishing PR https://github.com/OSGeo/grass/pull/2153 which creates the new radiobox for statusbar settings. I was a bit unsure how to cope with this task so I tried several ways, hopefully now I am on the right way and I will finish this PR soon. In the meantime I also created new icons for Map Display settings (you can take a look at https://github.com/OSGeo/grass/pull/2214) and I also opened the PR https://github.com/OSGeo/grass/pull/2216 improving a bit the design of Single-Window GUI at startup. This PR will be probably merged soon as well. |
| 236 | |
| 237 | '''2) What am I going to achieve for next week?'''\\ |
| 238 | The main task for the next week is to finish the PR https://github.com/OSGeo/grass/pull/2153. The one chapter about combobox removal (and statusbar redesign) will be finished then. However, there are still many things missing. The Projection page from GUI settings should be moved to Map Display settings, for instance. |
| 239 | |
| 240 | '''3) Is there any blocking issue?'''\\ |
| 241 | No, it isn't. |
