238 | | The main task for the next week is to finish the PR https://github.com/OSGeo/grass/pull/2153. The one chapter about combobox removal (and statusbar redesign) will be finished then. However, there are still many things missing. The Projection page from GUI settings should be moved to Map Display settings, for instance. |
239 | | |
240 | | '''3) Is there any blocking issue?'''\\ |
241 | | No, it isn't. |
| 238 | The main task for the next week is to finish the PR https://github.com/OSGeo/grass/pull/2153. The one chapter about combobox removal (statusbar redesign) will be finished then. However, there are still many things missing. The Projection page from GUI settings should be moved to Map Display settings, for instance, or EPSG text widget could be added to the main statusbar etc.. |
| 239 | |
| 240 | '''3) Is there any blocking issue?'''\\ |
| 241 | No, it isn't. |
