162 | | This week I worked on the new Map Display settings dialog which is accessible from the Map Display toolbar. I created a separate file for this purpose and proceed to move checkboxes from the Map Display status bar there - Render, AlignExtent, Resolution, and ShowRegion. The Render checkbox is also still accessible through the status bar, however other checkboxes were removed from the status bar combo box and are further available only from Map Display settings, for more info please see https://github.com/OSGeo/grass/pull/2031. Furthermore, I and Tomas Zigo managed to fix the closing event for the Map Notebook tab in the Single-Window GUI (see https://github.com/OSGeo/grass/pull/2072). |
| 162 | This week I worked on the new Map Display settings dialog which is accessible from the Map Display toolbar. I created a separate file for this purpose and proceed to move checkboxes from the Map Display status bar there - Render, !AlignExtent, Resolution, and !ShowRegion. The Render checkbox is also still accessible through the status bar, however other checkboxes were removed from the status bar combo box and are further available only from Map Display settings, for more info please see https://github.com/OSGeo/grass/pull/2031. Furthermore, I and Tomas Zigo managed to fix the closing event for the Map Notebook tab in the Single-Window GUI (see https://github.com/OSGeo/grass/pull/2072). |
