Changes between Version 10 and Version 11 of 1.2to2.0MigrationInstructions
12/13/07 13:41:24 (17 years ago)
tomfukushima
  • 1.2to2.0MigrationInstructions
    v10 v11
    882. Change to the !RepositoryAdmin directory (e.g. "C:\Program Files\!MapGuideOpenSource\Server\!RepositoryAdmin" on Windows).
    10 3. Run !BackUpOnlineRepositories.bat (or !BackUpOnlineRepositories.sh for Linux).
     103. Run !BackUpOnlineRepositories.bat (or !BackUpOnlineRepositories.sh for Linux).  '''Important: ensure that you do not use !BackUpOfflineRepositories.bat/sh here otherwise the next step will fail.'''
    1111
    12 4. Run !RestoreRepositories.bat (or !RestoreRepositories.sh for Linux).
     124. Run !RestoreRepositories.bat (or !RestoreRepositories.sh for Linux).  Check the output to make sure there are no errors.
    1313
    14 5. Windows: uninstall the 1.2 server (note that this does not delete the existing repositories). Or stop the server and try out the instructions for a side-by-side install: http://trac.osgeo.org/mapguide/wiki/InstallSideBySide1.2and2.0Apache.
     145. Windows: uninstall the 1.2 server (note that this does not delete the existing repositories). Or stop the server and try out the instructions for a side-by-side install: [wiki:InstallSideBySide1.2and2.0Apache side by side install].
    1515
    16166. Install the new MGOS 2.0 Server. Note that the server will fail to start if it tries to open old repositories.
