Changes between Version 3 and Version 4 of 1.2to2.0MigrationInstructions
- 12/13/07 11:04:50 (17 years ago)
v3 v4 1 1 == Migrate the repository == 2 2 The repository needs to be migrated because of the [wiki:MapGuideRfc23 Oracle Berkeley DB XML upgrade]. 3 4 (MGOS 2.0.0 Beta 1 note: You will need to download and install the files in the [http://download.osgeo.org/mapguide/releases/2.0.0-beta1/MissingBDXMLFiles.zip MissingBDXMLFiles.zip] file to do the steps below.)5 3 6 4 Here are the steps on how to migrate your data from MGOS 1.2 to MGOS 2.0 (note that these steps could take a long time if you have large repositories): … … 18 16 6. Install the new MGOS 2.0 Server. Note that the Server will fail to start if it tries to open old repositories. 19 17 20 7. Change to the !RepositoryAdmin directory (e.g. "C:\Program Files\!MapGuideOpenSource \Server\!RepositoryAdmin" or "/usr/local/mapguide/server/!RepositoryAdmin", etc.).18 7. Change to the !RepositoryAdmin directory (e.g. "C:\Program Files\!MapGuideOpenSource2.0\Server\!RepositoryAdmin" or "/usr/local/mapguide/server/!RepositoryAdmin", etc.). 21 19 22 20 10. Run !UpgradeRepositories.bat (or !UpgradeRepositories.sh for Linux).
