Changes between Version 8 and Version 9 of 1.2to2.0MigrationInstructions
12/13/07 11:53:25 (17 years ago)
stevedang
  • 1.2to2.0MigrationInstructions
    v8 v9
    661. Shut down the existing MG Server (MGOS 1.2) if it is running.
    8 2. Change to the !RepositoryAdmin directory (e.g. "C:\Program Files\!MapGuideOpenSource\Server\!RepositoryAdmin" or "/usr/local/mapguide/server/!RepositoryAdmin").
     82. Change to the !RepositoryAdmin directory (e.g. "C:\Program Files\!MapGuideOpenSource\Server\!RepositoryAdmin" on Windows).
    10103. Run !BackUpOnlineRepositories.bat (or !BackUpOnlineRepositories.sh for Linux).
    14145. Windows: uninstall the 1.2 server (note that this does not delete the existing repositories). Or stop the server and try out the instructions for a side-by-side install: http://trac.osgeo.org/mapguide/wiki/InstallSideBySide1.2and2.0Apache.
    1515
    16 6. Install the new MGOS 2.0 Server. Note that the Server will fail to start if it tries to open old repositories.
     166. Install the new MGOS 2.0 Server. Note that the server will fail to start if it tries to open old repositories.
    1717
    18187. Shut down the newly installed MG Server (MGOS 2.2) if it is running.
    1919
    20 8. Copy the repositories over to your new install. (From "C:\Program Files\!MapGuideOpenSource\Server\!Repositories" to "C:\Program Files\!MapGuideOpenSource2.0\Server\!Repositories" on Windows.)
     208. If the server is installed at a new location, delete the "empty" repositories (e.g "C:\Program Files\!MapGuideOpenSource2.0\Server\Repositories" on Windows), then copy the 1.2 repositories over to your new install (e.g. from "C:\Program Files\!MapGuideOpenSource\Server\Repositories" to "C:\Program Files\!MapGuideOpenSource2.0\Server\Repositories" on Windows).
    2121
    22 9. Change to the !RepositoryAdmin directory (e.g. "C:\Program Files\!MapGuideOpenSource2.0\Server\!RepositoryAdmin" or "/usr/local/mapguide/server/!RepositoryAdmin", etc.).
     229. Change to the !RepositoryAdmin directory (e.g. "C:\Program Files\!MapGuideOpenSource2.0\Server\!RepositoryAdmin" on Windows).
    2323
    242410. Run !UpgradeRepositories.bat (or !UpgradeRepositories.sh for Linux).
