Changes between Version 33 and Version 34 of ConfigureGuide22Windows
09/01/10 15:36:17 (14 years ago)
hluo
  • ConfigureGuide22Windows
    v33 v34
    107107Start Application Pool Immediately: true
    108108}}}
    109  * IIS configuration has several levels, the topmost levle is Server(or Host), then Sites, Virtual Directory. The configuration of lower layer can inherated from its parent layer. For this reason, we only configure at the Server layer. in the left panel, select what every your machine name is, there should be a list of configuration categories in the right panel. The important categories are Handler Mapping, ISAPI and CGI Restrictions, ISAPI Filter
     109 * IIS configuration has several levels, the topmost levle is Server(or Host), then Sites, Virtual Directory. The configuration of lower level can inherate from its parent layer. For this reason, we only configure Server level. In the left panel, select what every your machine name is, there should be a list of configuration categories in the right panel. The important categories are Handler Mapping, ISAPI and CGI Restrictions
    110110
    111111 * Handler Mapping->Add Module Mappings, add the following module mappings
    130130ISAPI or CGI Path: c:\mapguide-2.2-beta1\Web\www\mapagent\isapi_MapAgent.dll
    131131Description: MapGuide MapAgent ISAPI Handler
     132Allow Extension Path To Execute: True
    132133}}}
    133134   2. PHP ISAPI Handler
    135136ISAPI or CGI Path: c:\php\php5isapi.dll
    136137Description: PHP ISAPI Handler
     138Allow Extension Path To Execute: True
    137139}}}
    138140
