462 | | Because TileSetDefinitions are bound to a specific coordinate system, the CoordinateSystem element of the Map Definition will no longer be the single point of truth when determining if dynamic layers in a map require re-projection. Instead if a Map Definition references a TileSetDefinition, its CoordinateSystem element takes precedence over the one defined in the Map Definition. This requirement can be relaxed/lifted if/when we support raster re-projection of existing rendered tiles (Discussion required: Is this feasible?) |
| 462 | Because TileSetDefinitions are bound to a specific coordinate system, the CoordinateSystem element of the Map Definition will no longer be the single point of truth when determining if dynamic layers in a map require re-projection. Instead if a Map Definition references a TileSetDefinition, its CoordinateSystem element takes precedence over the one defined in the Map Definition. If a TileSetDefinition is referenced, all dynamic layers in the Map Definition will re-project to that Coordinate System instead of the one in the Map Definition. |
| 463 | |
| 464 | This requirement can be relaxed/lifted if/when we support raster re-projection of existing rendered tiles (Discussion required: Is this feasible?) |
