Changes between Version 6 and Version 7 of InstallSideBySide1.2and2.0IIS
- 01/08/08 05:58:41 (17 years ago)
v6 v7 23 23 }}} 24 24 == Install !MapGuide Web Extensions 2.0 == 25 We need to use the bundled Apache install because MGOS 2.0 uses the same IIS virtual directory as MGOS 1.2 and so two IIS installs will not work (this is due to the fact that the new MapGuide ISAPI agent requires some global settings for PHP and this ends up wrecking the 1.2 install. If anyone knows how to fix this we would be glad to hear about it).25 We need to use the bundled Apache install because MGOS 2.0 uses the same IIS virtual directory as MGOS 1.2 and so two IIS installs will not work (this is due to the fact that the new !MapGuide ISAPI agent requires some global settings for PHP and this ends up wrecking the 1.2 install---if anyone knows how to fix this we would be glad to hear about it). 26 26 27 27 The MGOS 2.0 installer currently sets some registry keys incorrectly. Before proceeding, export the HKEY_LOCAL_MACHINE\SOFTWARE\FASTCGI key using the registry editor.
