Changes between Initial Version and Version 1 of MapGuideRfc100
06/25/10 01:30:51 (14 years ago)
jng
  • MapGuideRfc100
     1
     2= !MapGuide RFC 100 - Web Tier support for testing expressions and filters =
     4This page contains an change request (RFC) for the !MapGuide Open Source project.
     5More !MapGuide RFCs can be found on the [wiki:MapGuideRfcs RFCs] page.
     8== Status ==
     10||RFC Template Version||(1.0)||
     11||Submission Date||(Date/Time submitted)||
     12||Last Modified||Jackie Ng, 25 June 2010||
     13||Author||Jackie Ng||
     14||RFC Status||draft||
     15||Implementation Status||pending||
     16||Proposed Milestone||2.3||
     17||Assigned PSC guide(s)||Jackie Ng||
     18||'''Voting History'''||||
     19||+1||||
     20||+0||||
     21||-0||||
     22||-1||||
     23||no vote|| ||
     25== Overview ==
     27This RFC proposes the Web tier APIs be extended to support the testing of FDO expressions.
     28
     29== Motivation ==
     30
     31The expression editor in MapGuide Maestro lacks the ability to test the entered FDO expression/filter for validity. While the simple solution would be to have Maestro use FDO directly (which provides services for testing/parsing expressions), this breaks portability (Maestro is a .net application. FDO's .net wrapper is not portable). Having this functionality available at the web tier level is a more convenient and portable solution.
     32
     33== Proposed Solution ==
     34
     35Add two new mapagent operations:
     36
     37 * Name: TESTEXPRESSION
     38 * Parameters:
     39   * VERSION: 1.0.0
     40   * LOCALE: en
     41   * EXPRESSION: (the FDO expression to test)
     42
     43 * Name: TESTFILTER
     44 * Parameters:
     45   * VERSION: 1.0.0
     46   * LOCALE: en
     47   * EXPRESSION: (the FDO filter to test)
     48
     49Add the supporting native APIs to MgFeatureService (exported to SWIG with PUBLISHED_API)
     50
     51{{{
     52class MgFeatureService
     53{
     54...
     55PUBLISHED_API:
     56    virtual bool TestExpression(CREFSTRING fdoExpr);
     57    virtual bool TestFilter(CREFSTRING fdoFilter);
     58...
     59};
     60}}}
     61
     62Maestro's wrapper API will be updated to support these new mapagent commands.
     63
     64== Implications ==
     65
     66This is an API addition. Existing APIs are unaffected. As this is an addition to a PlatformBase API, other implementations of MgFeatureService (eg. AutoCAD Map3D Geospatial API) will have to implement these APIs as well.
     67
     68== Test Plan ==
     69
     70Test the http and web tier APIs with a series of valid and invalid FDO expressions. Verify the return result is '''true''' for all valid FDO expressions. Verify the return result is '''false''' for all invalid FDO expressions.
     71
     72== Funding/Resources ==
     73
     74Community based
