Changes between Version 4 and Version 5 of MapGuideRfc116
06/16/11 16:19:54 (14 years ago)
NormOlsen
  • MapGuideRfc116
    v4 v5
    2323== Overview ==
    2424
    25 Geodetic coordinate system conversion is involved in a large portion of MapGuide data processing at both the server and client levels.  Presuming the acceptance and implementation of CS-MAP RFC #5, it is proposed that the MgCoordinateSystem Application Programmers Interface (API) be enhanced to increase the performance of coordinate conversions at both the server and client levels of MapGuide without changing the behavior of any existing member of the API.
     25Geodetic coordinate system conversion is involved in a large portion of MapGuide data processing at both the server and client levels.  Presuming the acceptance and implementation of CS-MAP RFC !#5, it is proposed that the MgCoordinateSystem Application Programmers Interface (API) be enhanced to increase the performance of coordinate conversions at both the server and client levels of MapGuide without changing the behavior of any existing member of the API.
    2626
    2727== Motivation ==
    9494=== Provide Addiional Batch Coordinate Conversion Capability ===
    9595
    96 A batch coordinate conversion capability currently exists in the MgCoordinateSystemTransformation object.  The performance of this capability is expected to increase due to the refactoring of the Transform code proposed immediately above.  However, this function requires that, for example, 3D coordinates are provided in three distinct arrays; specifically the easting/X/Longitude coordinates in one distinct array of doubles, the northing/Y/Latitude coordinates in a separate distinct array of doubles, and a third separate and distinct array of double for the elevation/Z/height coordinate.  There are few, if any, applications which maintain or utilize coordinate data in this form.  Thus, to take advantage of the batch conversion facility currently in place, the tradition form of coordinate data (i.e. double [][3]) has to be reformatted into the distinct array form prior to conversion, and then reformatted back to the traditional form after conversion.  Thus, what performance improvement is provided by the batch conversion facility is used up, and then some, by the reformatting process.
     96A batch coordinate conversion capability currently exists in the MgCoordinateSystemTransformation object.  The performance of this capability is expected to increase due to the refactoring of the Transform code proposed immediately above.  However, this function requires that, for example, 3D coordinates are provided in three distinct arrays; specifically the easting/X/Longitude coordinates in one distinct array of doubles, the northing/Y/Latitude coordinates in a separate distinct array of doubles, and a third separate and distinct array of double for the elevation/Z/height coordinate.  There are few, if any, applications which maintain or utilize coordinate data in this form.  Thus, to take advantage of the batch conversion facility currently in place, the tradition form of coordinate data (i.e. double ![][3]) has to be reformatted into the distinct array form prior to conversion, and then reformatted back to the traditional form after conversion.  Thus, what performance improvement is provided by the batch conversion facility is used up, and then some, by the reformatting process.
    9797It is, therefore proposed, that two new functions be added to the MgCoordinateSystemTransformation object be added which will have signatures suggested by the following:
    9898
