Changes between Version 29 and Version 30 of MapGuideRfc119
- 07/19/11 20:06:45 (14 years ago)
MapGuideRfc119
v29 v30 83 83 84 84 85 Now the normal workflow for evaluating the URL content of a feature is: 86 85 Now the normal workflow for evaluating the URL content of a feature is:[[BR]] 87 86 The application first check '!ContentOverride' child element of the URL element. If its value is not empty and happens to be one of the property names of the feature class the layer is based on, then fetch the actual value(which may be a string FDO expression) from that property of the feature and evaluate the actual value as a FDO expression. Otherwise, ignore it and check 'Content' child and evaluate its value as a FDO expression. 88 87
