Changes between Version 12 and Version 13 of MapGuideRfc126
05/08/13 04:59:00 (12 years ago)
jng
  • MapGuideRfc126
    v12 v13
    231231
    232232{{{
    233 <?xml version="1.0" encoding="UTF-8"?>
    234233<FeatureInformation>
    235 <FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer id="2dbc571a-b5a1-11e2-8004-080027004461">  <Class id="SHP_Schema:Parcels">   <ID>DiQAAA==</ID>  </Class> </Layer></FeatureSet><Tooltip />
    236 <Hyperlink />
    237 <InlineSelectionImage />
    238 <Attributes>
    239 <BatchPropertyCollection><PropertyCollection><Property><Name>_MgLayerName</Name><Type>string</Type><Value>Parcels</Value></Property><Property><Name>_MgFeatureBoundingBox</Name><Type>string</Type><Value>-87.719208640129452 43.747730625310957 -87.71745819670727 43.748609259038986</Value></Property><Property><Name>Description1</Name><Type>string</Type><Value>ORIG. PLAT</Value></Property><Property><Name>Zone</Name><Type>string</Type><Value>EXM</Value></Property><Property><Name>Acreage</Name><Type>string</Type><Value>3.21</Value></Property><Property><Name>Lot Dimensions</Name><Type>string</Type><Value>IRREG</Value></Property><Property><Name>Owner</Name><Type>string</Type><Value>CITY OF SHEBOYGAN</Value></Property><Property><Name>Description2</Name><Type>string</Type><Value>ALL OF BLOCKS 186 &amp; 187, AND</Value></Property><Property><Name>Description3</Name><Type>string</Type><Value>VACATED S. 11TH ST. BETWEEN</Value></Property><Property><Name>Billing Address</Name><Type>string</Type><Value>828 CENTER AVE</Value></Property><Property><Name>Lot Size (SqFt)</Name><Type>string</Type><Value>140000</Value></Property><Property><Name>Description4</Name><Type>string</Type><Value>SD BLOCKS, EXCEPT THE W 10&apos;</Value></Property></PropertyCollection></BatchPropertyCollection></Attributes>
     234<FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd">
     235<Layer id="a754a6f0-b7d5-11e2-8004-080027004461">
     236<Class id="SHP_Schema:Parcels">
     237<ID>1R8AAA==</ID>
     238</Class>
     239</Layer>
     240</FeatureSet>
     241<Tooltip></Tooltip>
     242<Hyperlink></Hyperlink>
     243<InlineSelectionImage></InlineSelectionImage>
     244<SelectedFeatures>
     245<SelectedLayer id="a754a6f0-b7d5-11e2-8004-080027004461" name="Parcels">
     246<LayerMetadata>
     247<Property>
     248<Name>RLDESCR1</Name>
     249<Type>9</Type>
     250<DisplayName>Description1</DisplayName>
     251</Property>
     252<Property>
     253<Name>RTYPE</Name>
     254<Type>9</Type>
     255<DisplayName>Zone</DisplayName>
     256</Property>
     257<Property>
     258<Name>RACRE</Name>
     259<Type>9</Type>
     260<DisplayName>Acreage</DisplayName>
     261</Property>
     262<Property>
     263<Name>RLOT</Name>
     264<Type>9</Type>
     265<DisplayName>Lot Dimensions</DisplayName>
     266</Property>
     267<Property>
     268<Name>RNAME</Name>
     269<Type>9</Type>
     270<DisplayName>Owner</DisplayName>
     271</Property>
     272<Property>
     273<Name>RLDESCR2</Name>
     274<Type>9</Type>
     275<DisplayName>Description2</DisplayName>
     276</Property>
     277<Property>
     278<Name>RLDESCR3</Name>
     279<Type>9</Type>
     280<DisplayName>Description3</DisplayName>
     281</Property>
     282<Property>
     283<Name>RBILAD</Name>
     284<Type>9</Type>
     285<DisplayName>Billing Address</DisplayName>
     286</Property>
     287<Property>
     288<Name>RSQFT</Name>
     289<Type>7</Type>
     290<DisplayName>Lot Size (SqFt)</DisplayName>
     291</Property>
     292<Property>
     293<Name>RLDESCR4</Name>
     294<Type>9</Type>
     295<DisplayName>Description4</DisplayName>
     296</Property>
     297</LayerMetadata>
     298<Feature>
     299<Bounds>-87.722788142888234 43.755335868606466 -87.721634440510442 43.756252668096828</Bounds>
     300<Property>
     301<Name>Description1</Name>
     302<Value>ORIGINAL PLAT</Value>
     303</Property>
     304<Property>
     305<Name>Zone</Name>
     306<Value>MER</Value>
     307</Property>
     308<Property>
     309<Name>Acreage</Name>
     310<Value>1.61</Value>
     311</Property>
     312<Property>
     313<Name>Lot Dimensions</Name>
     314<Value>IRREG</Value>
     315</Property>
     316<Property>
     317<Name>Owner</Name>
     318<Value>MRED (14TH/ERIE) ASS</Value>
     319</Property>
     320<Property>
     321<Name>Description2</Name>
     322<Value>CSM REC IN VOL 17 P 242-4 AS</Value>
     323</Property>
     324<Property>
     325<Name>Description3</Name>
     326<Value>DOC #1593757 ROD BEING PRT</Value>
     327</Property>
     328<Property>
     329<Name>Billing Address</Name>
     330<Value>W228 N745 WESTMOUND</Value>
     331</Property>
     332<Property>
     333<Name>Lot Size (SqFt)</Name>
     334<Value>70140</Value>
     335</Property>
     336<Property>
     337<Name>Description4</Name>
     338<Value>OF LOTS 2 & 6 AND ALL OF</Value>
     339</Property>
     340</Feature>
     341</SelectedLayer>
     342</SelectedFeatures>
    240343</FeatureInformation>
    241344}}}
    244347
    245348{{{
    246 <?xml version="1.0" encoding="UTF-8"?>
    247349<FeatureInformation>
    248 <FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer id="2dbc571a-b5a1-11e2-8004-080027004461">  <Class id="SHP_Schema:Parcels">   <ID>DiQAAA==</ID>  </Class> </Layer></FeatureSet><Tooltip />
    249 <Hyperlink />
     350<FeatureSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd">
     351<Layer id="e3ec8e66-b7d5-11e2-8004-080027004461">
     352<Class id="SHP_Schema:Parcels">
     353<ID>2x4AAA==</ID>
     354</Class>
     355</Layer>
     356</FeatureSet>
     357<Tooltip></Tooltip>
     358<Hyperlink></Hyperlink>
    250359<InlineSelectionImage>
    251 <MimeType>
    252 image/png</MimeType>
    253 <Content>
    254 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</Content>
     360<MimeType>image/png</MimeType>
     361<Content>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</Content>
    255362</InlineSelectionImage>
    256 <Attributes>
    257 <BatchPropertyCollection><PropertyCollection><Property><Name>_MgLayerName</Name><Type>string</Type><Value>Parcels</Value></Property><Property><Name>_MgFeatureBoundingBox</Name><Type>string</Type><Value>-87.719208640129452 43.747730625310957 -87.71745819670727 43.748609259038986</Value></Property><Property><Name>Description1</Name><Type>string</Type><Value>ORIG. PLAT</Value></Property><Property><Name>Zone</Name><Type>string</Type><Value>EXM</Value></Property><Property><Name>Acreage</Name><Type>string</Type><Value>3.21</Value></Property><Property><Name>Lot Dimensions</Name><Type>string</Type><Value>IRREG</Value></Property><Property><Name>Owner</Name><Type>string</Type><Value>CITY OF SHEBOYGAN</Value></Property><Property><Name>Description2</Name><Type>string</Type><Value>ALL OF BLOCKS 186 &amp; 187, AND</Value></Property><Property><Name>Description3</Name><Type>string</Type><Value>VACATED S. 11TH ST. BETWEEN</Value></Property><Property><Name>Billing Address</Name><Type>string</Type><Value>828 CENTER AVE</Value></Property><Property><Name>Lot Size (SqFt)</Name><Type>string</Type><Value>140000</Value></Property><Property><Name>Description4</Name><Type>string</Type><Value>SD BLOCKS, EXCEPT THE W 10&apos;</Value></Property></PropertyCollection></BatchPropertyCollection></Attributes>
     363<SelectedFeatures>
     364<SelectedLayer id="e3ec8e66-b7d5-11e2-8004-080027004461" name="Parcels">
     365<LayerMetadata>
     366<Property>
     367<Name>RLDESCR1</Name>
     368<Type>9</Type>
     369<DisplayName>Description1</DisplayName>
     370</Property>
     371<Property>
     372<Name>RTYPE</Name>
     373<Type>9</Type>
     374<DisplayName>Zone</DisplayName>
     375</Property>
     376<Property>
     377<Name>RACRE</Name>
     378<Type>9</Type>
     379<DisplayName>Acreage</DisplayName>
     380</Property>
     381<Property>
     382<Name>RLOT</Name>
     383<Type>9</Type>
     384<DisplayName>Lot Dimensions</DisplayName>
     385</Property>
     386<Property>
     387<Name>RNAME</Name>
     388<Type>9</Type>
     389<DisplayName>Owner</DisplayName>
     390</Property>
     391<Property>
     392<Name>RLDESCR2</Name>
     393<Type>9</Type>
     394<DisplayName>Description2</DisplayName>
     395</Property>
     396<Property>
     397<Name>RLDESCR3</Name>
     398<Type>9</Type>
     399<DisplayName>Description3</DisplayName>
     400</Property>
     401<Property>
     402<Name>RBILAD</Name>
     403<Type>9</Type>
     404<DisplayName>Billing Address</DisplayName>
     405</Property>
     406<Property>
     407<Name>RSQFT</Name>
     408<Type>7</Type>
     409<DisplayName>Lot Size (SqFt)</DisplayName>
     410</Property>
     411<Property>
     412<Name>RLDESCR4</Name>
     413<Type>9</Type>
     414<DisplayName>Description4</DisplayName>
     415</Property>
     416</LayerMetadata>
     417<Feature>
     418<Bounds>-87.722795366494324 43.756662887792743 -87.721545117334017 43.757359091595923</Bounds>
     419<Property>
     420<Name>Description1</Name>
     421<Value>ORIGINAL PLAT</Value>
     422</Property>
     423<Property>
     424<Name>Zone</Name>
     425<Value>EXM</Value>
     426</Property>
     427<Property>
     428<Name>Acreage</Name>
     429<Value>1.12</Value>
     430</Property>
     431<Property>
     432<Name>Lot Dimensions</Name>
     433<Value>IRREG</Value>
     434</Property>
     435<Property>
     436<Name>Owner</Name>
     437<Value>REHABILITATION CENTE</Value>
     438</Property>
     439<Property>
     440<Name>Description2</Name>
     441<Value>THE W 1/2 OF LOT 1, ALL OF</Value>
     442</Property>
     443<Property>
     444<Name>Description3</Name>
     445<Value>LOTS 2, 3, 4 & 5; THE N</Value>
     446</Property>
     447<Property>
     448<Name>Billing Address</Name>
     449<Value>P O BOX 685</Value>
     450</Property>
     451<Property>
     452<Name>Lot Size (SqFt)</Name>
     453<Value>48870</Value>
     454</Property>
     455<Property>
     456<Name>Description4</Name>
     457<Value>50.00' OF LOT 6, ALSO THE N</Value>
     458</Property>
     459</Feature>
     460</SelectedLayer>
     461</SelectedFeatures>
    258462</FeatureInformation>
    259463}}}
    280484
    281485{{{
    282 <?xml version="1.0" encoding="UTF-8"?>
    283486<FeatureInformation>
    284487<FeatureSet />
    285 <Tooltip>Parcel\nName: WHITE, RICHARD\nAddress: 1627 INDIANA AVE</Tooltip>
     488<Tooltip>Parcel\nName: TOBOTIPE, INC\nAddress: 4902 N. 18TH ST.</Tooltip>
    286489<Hyperlink />
    287490<InlineSelectionImage />
    366569
    367570'''Discussion required: Currently, the following parts of the Fusion selection structure are not set by this new QUERYMAPFEATURES operation:'''
    368  * '''propertynames (v2.6.0 QUERYMAPFEATURES will return the mapped property name and not the FDO property name if mapped)'''
    369  * '''metadata      (what widgets/functionality use this information?)'''
    370  * '''metadatanames (what widgets/functionality use this information?)'''
     571 * '''metadata      (what widgets/functionality use this information? Current implementation blanks all values)'''
    371572'''Should v2.6.0 QUERYMAPFEATURE also accomodate for such information?'''
    372573
