| 1 | |
| 2 | = !MapGuide RFC 134 - HTTP Runtime Map Creation = |
| 3 | |
| 4 | This page contains a change request (RFC) for the !MapGuide Open Source project. |
| 5 | More !MapGuide RFCs can be found on the [wiki:MapGuideRfcs RFCs] page. |
| 6 | |
| 7 | |
| 8 | == Status == |
| 9 | |
| 10 | ||RFC Template Version||(1.0)|| |
| 11 | ||Submission Date||13 May 2013|| |
| 12 | ||Last Modified||13 May 2013|| |
| 13 | ||Author||Jackie Ng|| |
| 14 | ||RFC Status||draft|| |
| 15 | ||Implementation Status||pending|| |
| 16 | ||Proposed Milestone||2.6|| |
| 17 | ||Assigned PSC guide(s)||(when determined)|| |
| 18 | ||'''Voting History'''||(vote date)|| |
| 19 | ||+1|||| |
| 20 | ||+0|||| |
| 21 | ||-0|||| |
| 22 | ||-1|||| |
| 23 | ||no vote|| || |
| 24 | |
| 25 | == Overview == |
| 26 | |
| 27 | This RFC proposes to add support for creating Runtime Maps via the mapagent |
| 28 | |
| 29 | == Motivation == |
| 30 | |
| 31 | It is currently not possible for a client-side application to be able to create a Runtime Map. Current workarounds include: |
| 32 | |
| 33 | a) Implementing a helper script via the Web Extensions API to return the key pieces of information needed to work and interact with a runtime map. The [http://dev.openlayers.org/releases/OpenLayers-2.12/examples/mapguide.html MapGuide OpenLayers sample] requires the client application specify key missing information that only the Web Extensions API can provide: |
| 34 | * Session ID |
| 35 | * Map Name |
| 36 | * Coordinate System (WKT/EPSG code) |
| 37 | * Meters-Per-Unit |
| 38 | b) Using the Maestro API in .net to construct the Runtime Map client-side by building the expected binary blob (that will be saved server-side) containing the initial runtime map state. This is somewhat of a hack as it relies on undocumented internals of the runtime map blob being serialized that could change with any new release of MapGuide. |
| 39 | |
| 40 | There is no way to build a Runtime Map client-side without the assistance of the Web Extensions API or a hacky solution like Maestro. This RFC addresses this shortcoming. |
| 41 | |
| 42 | == Proposed Solution == |
| 43 | |
| 44 | We introduce a new operation to the mapagent: CREATERUNTIMEMAP |
| 45 | |
| 46 | This new operation has the following parameters (in addition to the standard OPERATION, VERSION, LOCALE, SESSION, USERNAME, PASSWORD and FORMAT parameters) |
| 47 | |
| 48 | ||Name||Description||Required|| |
| 49 | ||MAPDEFINITION||The resource id of the Map Definition to create a Runtime Map from||Yes|| |
| 50 | ||REQUESTEDFEATURES||A bitmask specifying what pieces of information to includein the CREATERUNTIMEMAP response||No|| |
| 51 | ||ICONSPERSCALERANGE||The number of icons to render inline (as base64 images) per scale range in each layer of the map||No|| |
| 52 | |
| 53 | The REQUESTEDFEATURES parameters can be logically ORed with the following values: |
| 54 | * 1 - The basic layer and group structure is returned. |
| 55 | * 2 - Associated style icons are returned with each layer. This value only takes effect if (1) was logically ORed into the mask. |
| 56 | * 4 - Feature Source information is included with each layer. This value only takes effect if (1) was logically ORed into the mask. |
| 57 | |
| 58 | The ICONSPERSCALERANGE parameter is used to apply "theme compression". If a given layer contains a scale range whose number of rules exceeds the given number, only the first and last rule items will have icons rendered inline, with the assumption that a client-application will "compress" the remaining rules when displaying in an interactive legend control. This is what the AJAX and Fusion viewers both currently do. If this parameter is not specified, and the REQUESTEDFEATURES include a request for icons (2), then a default value of 25 will be used (same value we currently use for LoadMap.php and LoadScaleRanges.php for Fusion). |
| 59 | |
| 60 | Inline icons are rendered as base64 strings. With an associated mime type included, allowing for browsers to construct the relevant data URIs client-side. |
| 61 | |
| 62 | The REQUESTDFEATURES parameter allows for scalable CREATERUNTIMEMAP responses depending on the needs of the client application. As part of this RFC, Fusion will use CREATERUNTIMEMAP for its map initialization if it determined that the server support is there, allowing it to bypass the asynchronous call chain to LoadMap.php and LoadScaleRanges.php |
| 63 | |
| 64 | JSON output format is supported, and provides the same benefits as other operations that support JSON output. |
| 65 | |
| 66 | Some example responses below (all using the Sheboygan Map Definition): |
| 67 | |
| 68 | A CREATERUNTIMEMAP request without the REQUESTEDFEATURES looks like this: |
| 69 | |
| 70 | {{{ |
| 71 | <RuntimeMap> |
| 72 | <SiteVersion>2.6.0.0</SiteVersion> |
| 73 | <SessionId>efaa467a-bbcd-11e2-8000-080027004461_en_MTI3LjAuMC4x0B060B050B04</SessionId> |
| 74 | <Name>Sheboygan</Name> |
| 75 | <MapDefinition>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</MapDefinition> |
| 76 | <CoordinateSystem> |
| 77 | <Wkt>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</Wkt> |
| 78 | <MentorCode>LL84</MentorCode> |
| 79 | <EpsgCode>4326</EpsgCode> |
| 80 | <MetersPerUnit>111319.49079327358</MetersPerUnit> |
| 81 | </CoordinateSystem> |
| 82 | <Extents> |
| 83 | <LowerLeftCoordinate> |
| 84 | <X>-87.764986990962839</X> |
| 85 | <Y>43.691398128787782</Y> |
| 86 | </LowerLeftCoordinate> |
| 87 | <UpperRightCoordinate> |
| 88 | <X>-87.695521510899724</X> |
| 89 | <Y>43.797520000480347</Y> |
| 90 | </UpperRightCoordinate> |
| 91 | </Extents> |
| 92 | </RuntimeMap> |
| 93 | }}} |
| 94 | |
| 95 | This response contains the minimal information required for a client mapping library like OpenLayers to build a basic map viewer out of. It also contains the required session id and map name needed to dispatch additional mapagent requests for other operations that operate against the runtime map like rendering (GETDYNAMICMAPOVERLAYIMAGE) and feature selection (QUERYMAPFEATURES). The MapGuide Site Version is included so the client application can make (generally safe) assumptions about what level of API/operation support is available from the mapagent. |
| 96 | |
| 97 | The session id is either passed in via the SESSION request parameter, or generated via the USERNAME/PASSWORD request parameters or a successful HTTP basic authentication challenge. Therefore, CREATERUNTIMEMAP serves the same function as the CREATESESSION operation, negating the need to fire off this request first beforehand by the client application. |
| 98 | |
| 99 | The various permutations of the REQUESTEDFEATURES bitmask extend upon the basic minimal XML response with additional information, all detailed below. |
| 100 | |
| 101 | REQUESTEDFEATURES = 1 (with basic layer/group structure): |
| 102 | {{{ |
| 103 | <RuntimeMap> |
| 104 | <SiteVersion>2.6.0.0</SiteVersion> |
| 105 | <SessionId>b5790166-bbce-11e2-8000-080027004461_en_MTI3LjAuMC4x0B060B050B04</SessionId> |
| 106 | <Name>Sheboygan</Name> |
| 107 | <MapDefinition>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</MapDefinition> |
| 108 | <CoordinateSystem> |
| 109 | <Wkt>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</Wkt> |
| 110 | <MentorCode>LL84</MentorCode> |
| 111 | <EpsgCode>4326</EpsgCode> |
| 112 | <MetersPerUnit>111319.49079327358</MetersPerUnit> |
| 113 | </CoordinateSystem> |
| 114 | <Extents> |
| 115 | <LowerLeftCoordinate> |
| 116 | <X>-87.764986990962839</X> |
| 117 | <Y>43.691398128787782</Y> |
| 118 | </LowerLeftCoordinate> |
| 119 | <UpperRightCoordinate> |
| 120 | <X>-87.695521510899724</X> |
| 121 | <Y>43.797520000480347</Y> |
| 122 | </UpperRightCoordinate> |
| 123 | </Extents> |
| 124 | <Group> |
| 125 | <Name>Base Map</Name> |
| 126 | <LegendLabel>Base Map</LegendLabel> |
| 127 | <ObjectId>b57caaf0-bbce-11e2-8000-080027004461</ObjectId> |
| 128 | <DisplayInLegend>true</DisplayInLegend> |
| 129 | <ExpandInLegend>true</ExpandInLegend> |
| 130 | <Visible>true</Visible> |
| 131 | <ActuallyVisible>true</ActuallyVisible> |
| 132 | <Layer> |
| 133 | <Type>1</Type> |
| 134 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</LayerDefinition> |
| 135 | <Name>Islands</Name> |
| 136 | <LegendLabel>Islands</LegendLabel> |
| 137 | <ObjectId>b57cf910-bbce-11e2-8001-080027004461</ObjectId> |
| 138 | <DisplayInLegend>true</DisplayInLegend> |
| 139 | <ExpandInLegend>true</ExpandInLegend> |
| 140 | <Visible>true</Visible> |
| 141 | <ActuallyVisible>true</ActuallyVisible> |
| 142 | </Layer> |
| 143 | <Layer> |
| 144 | <Type>1</Type> |
| 145 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</LayerDefinition> |
| 146 | <Name>Hydrography</Name> |
| 147 | <LegendLabel>Hydrography</LegendLabel> |
| 148 | <ObjectId>b57cf910-bbce-11e2-8002-080027004461</ObjectId> |
| 149 | <DisplayInLegend>true</DisplayInLegend> |
| 150 | <ExpandInLegend>true</ExpandInLegend> |
| 151 | <Visible>true</Visible> |
| 152 | <ActuallyVisible>true</ActuallyVisible> |
| 153 | </Layer> |
| 154 | <Layer> |
| 155 | <Type>1</Type> |
| 156 | <LayerDefinition>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</LayerDefinition> |
| 157 | <Name>CityLimits</Name> |
| 158 | <LegendLabel>CityLimits</LegendLabel> |
| 159 | <ObjectId>b57cf910-bbce-11e2-8003-080027004461</ObjectId> |
| 160 | <DisplayInLegend>true</DisplayInLegend> |
| 161 | <ExpandInLegend>true</ExpandInLegend> |
| 162 | <Visible>true</Visible> |
| 163 | <ActuallyVisible>true</ActuallyVisible> |
| 164 | </Layer> |
| 165 | </Group> |
| 166 | <Group> |
| 167 | <Name>Municipal</Name> |
| 168 | <LegendLabel>Municipal</LegendLabel> |
| 169 | <ObjectId>b57caaf0-bbce-11e2-8001-080027004461</ObjectId> |
| 170 | <DisplayInLegend>true</DisplayInLegend> |
| 171 | <ExpandInLegend>true</ExpandInLegend> |
| 172 | <Visible>true</Visible> |
| 173 | <ActuallyVisible>true</ActuallyVisible> |
| 174 | <Layer> |
| 175 | <Type>1</Type> |
| 176 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</LayerDefinition> |
| 177 | <Name>Districts</Name> |
| 178 | <LegendLabel>Districts</LegendLabel> |
| 179 | <ObjectId>b57cd200-bbce-11e2-8002-080027004461</ObjectId> |
| 180 | <DisplayInLegend>true</DisplayInLegend> |
| 181 | <ExpandInLegend>true</ExpandInLegend> |
| 182 | <Visible>true</Visible> |
| 183 | <ActuallyVisible>false</ActuallyVisible> |
| 184 | </Layer> |
| 185 | <Layer> |
| 186 | <Type>1</Type> |
| 187 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</LayerDefinition> |
| 188 | <Name>Buildings</Name> |
| 189 | <LegendLabel>Buildings</LegendLabel> |
| 190 | <ObjectId>b57cd200-bbce-11e2-8003-080027004461</ObjectId> |
| 191 | <DisplayInLegend>true</DisplayInLegend> |
| 192 | <ExpandInLegend>true</ExpandInLegend> |
| 193 | <Visible>true</Visible> |
| 194 | <ActuallyVisible>true</ActuallyVisible> |
| 195 | </Layer> |
| 196 | <Layer> |
| 197 | <Type>1</Type> |
| 198 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</LayerDefinition> |
| 199 | <Name>Parcels</Name> |
| 200 | <LegendLabel>Parcels</LegendLabel> |
| 201 | <ObjectId>b57cf910-bbce-11e2-8000-080027004461</ObjectId> |
| 202 | <DisplayInLegend>true</DisplayInLegend> |
| 203 | <ExpandInLegend>true</ExpandInLegend> |
| 204 | <Visible>true</Visible> |
| 205 | <ActuallyVisible>true</ActuallyVisible> |
| 206 | </Layer> |
| 207 | </Group> |
| 208 | <Group> |
| 209 | <Name>Transportation</Name> |
| 210 | <LegendLabel>Transportation</LegendLabel> |
| 211 | <ObjectId>b57caaf0-bbce-11e2-8002-080027004461</ObjectId> |
| 212 | <DisplayInLegend>true</DisplayInLegend> |
| 213 | <ExpandInLegend>true</ExpandInLegend> |
| 214 | <Visible>true</Visible> |
| 215 | <ActuallyVisible>true</ActuallyVisible> |
| 216 | <Layer> |
| 217 | <Type>1</Type> |
| 218 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</LayerDefinition> |
| 219 | <Name>Roads</Name> |
| 220 | <LegendLabel>Roads</LegendLabel> |
| 221 | <ObjectId>b57cd200-bbce-11e2-8000-080027004461</ObjectId> |
| 222 | <DisplayInLegend>true</DisplayInLegend> |
| 223 | <ExpandInLegend>true</ExpandInLegend> |
| 224 | <Visible>true</Visible> |
| 225 | <ActuallyVisible>true</ActuallyVisible> |
| 226 | </Layer> |
| 227 | <Layer> |
| 228 | <Type>1</Type> |
| 229 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</LayerDefinition> |
| 230 | <Name>Rail Lines</Name> |
| 231 | <LegendLabel>Rail Lines</LegendLabel> |
| 232 | <ObjectId>b57cd200-bbce-11e2-8001-080027004461</ObjectId> |
| 233 | <DisplayInLegend>true</DisplayInLegend> |
| 234 | <ExpandInLegend>true</ExpandInLegend> |
| 235 | <Visible>false</Visible> |
| 236 | <ActuallyVisible>false</ActuallyVisible> |
| 237 | </Layer> |
| 238 | </Group> |
| 239 | </RuntimeMap> |
| 240 | }}} |
| 241 | |
| 242 | REQUESTEDFEATURES = 3 (Basic layer/group structure with inline icons) |
| 243 | {{{ |
| 244 | <RuntimeMap> |
| 245 | <SiteVersion>2.6.0.0</SiteVersion> |
| 246 | <SessionId>eaf1bcda-bbd2-11e2-8000-080027004461_en_MTI3LjAuMC4x0B060B050B04</SessionId> |
| 247 | <Name>Sheboygan</Name> |
| 248 | <MapDefinition>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</MapDefinition> |
| 249 | <CoordinateSystem> |
| 250 | <Wkt>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</Wkt> |
| 251 | <MentorCode>LL84</MentorCode> |
| 252 | <EpsgCode>4326</EpsgCode> |
| 253 | <MetersPerUnit>111319.49079327358</MetersPerUnit> |
| 254 | </CoordinateSystem> |
| 255 | <Extents> |
| 256 | <LowerLeftCoordinate> |
| 257 | <X>-87.764986990962839</X> |
| 258 | <Y>43.691398128787782</Y> |
| 259 | </LowerLeftCoordinate> |
| 260 | <UpperRightCoordinate> |
| 261 | <X>-87.695521510899724</X> |
| 262 | <Y>43.797520000480347</Y> |
| 263 | </UpperRightCoordinate> |
| 264 | </Extents> |
| 265 | <Group> |
| 266 | <Name>Base Map</Name> |
| 267 | <LegendLabel>Base Map</LegendLabel> |
| 268 | <ObjectId>eaf58d7e-bbd2-11e2-8000-080027004461</ObjectId> |
| 269 | <DisplayInLegend>true</DisplayInLegend> |
| 270 | <ExpandInLegend>true</ExpandInLegend> |
| 271 | <Visible>true</Visible> |
| 272 | <ActuallyVisible>true</ActuallyVisible> |
| 273 | <Layer> |
| 274 | <Type>1</Type> |
| 275 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</LayerDefinition> |
| 276 | <Name>Islands</Name> |
| 277 | <LegendLabel>Islands</LegendLabel> |
| 278 | <ObjectId>eaf5db9e-bbd2-11e2-8000-080027004461</ObjectId> |
| 279 | <DisplayInLegend>true</DisplayInLegend> |
| 280 | <ExpandInLegend>true</ExpandInLegend> |
| 281 | <Visible>true</Visible> |
| 282 | <ActuallyVisible>true</ActuallyVisible> |
| 283 | <ScaleRange> |
| 284 | <MinScale>0</MinScale> |
| 285 | <MaxScale>1000000000000</MaxScale> |
| 286 | <Rule> |
| 287 | <GeometryType>3</GeometryType> |
| 288 | <ThemeCategory>0</ThemeCategory> |
| 289 | <LegendLabel/> |
| 290 | <Filter/> |
| 291 | <Icon> |
| 292 | <MimeType>image/png</MimeType> |
| 293 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWO8emINAymAiSTVoxpGNQwpDQAvoAJpPgoElwAAAABJRU5ErkJggg==</Content> |
| 294 | </Icon> |
| 295 | </Rule> |
| 296 | </ScaleRange> |
| 297 | </Layer> |
| 298 | <Layer> |
| 299 | <Type>1</Type> |
| 300 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</LayerDefinition> |
| 301 | <Name>Hydrography</Name> |
| 302 | <LegendLabel>Hydrography</LegendLabel> |
| 303 | <ObjectId>eaf5db9e-bbd2-11e2-8001-080027004461</ObjectId> |
| 304 | <DisplayInLegend>true</DisplayInLegend> |
| 305 | <ExpandInLegend>true</ExpandInLegend> |
| 306 | <Visible>true</Visible> |
| 307 | <ActuallyVisible>true</ActuallyVisible> |
| 308 | <ScaleRange> |
| 309 | <MinScale>0</MinScale> |
| 310 | <MaxScale>1000000000000</MaxScale> |
| 311 | <Rule> |
| 312 | <GeometryType>3</GeometryType> |
| 313 | <ThemeCategory>0</ThemeCategory> |
| 314 | <LegendLabel/> |
| 315 | <Filter/> |
| 316 | <Icon> |
| 317 | <MimeType>image/png</MimeType> |
| 318 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWNcffwlAymAiSTVoxpGNQwpDQBmNQJ7CUalHwAAAABJRU5ErkJggg==</Content> |
| 319 | </Icon> |
| 320 | </Rule> |
| 321 | </ScaleRange> |
| 322 | </Layer> |
| 323 | <Layer> |
| 324 | <Type>1</Type> |
| 325 | <LayerDefinition>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</LayerDefinition> |
| 326 | <Name>CityLimits</Name> |
| 327 | <LegendLabel>CityLimits</LegendLabel> |
| 328 | <ObjectId>eaf5db9e-bbd2-11e2-8002-080027004461</ObjectId> |
| 329 | <DisplayInLegend>true</DisplayInLegend> |
| 330 | <ExpandInLegend>true</ExpandInLegend> |
| 331 | <Visible>true</Visible> |
| 332 | <ActuallyVisible>true</ActuallyVisible> |
| 333 | <ScaleRange> |
| 334 | <MinScale>0</MinScale> |
| 335 | <MaxScale>10000</MaxScale> |
| 336 | <Rule> |
| 337 | <GeometryType>3</GeometryType> |
| 338 | <ThemeCategory>0</ThemeCategory> |
| 339 | <LegendLabel/> |
| 340 | <Filter/> |
| 341 | <Icon> |
| 342 | <MimeType>image/png</MimeType> |
| 343 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWM8cOAAAymAiSTVoxpGNQwpDQAT+QJghokBTgAAAABJRU5ErkJggg==</Content> |
| 344 | </Icon> |
| 345 | </Rule> |
| 346 | </ScaleRange> |
| 347 | <ScaleRange> |
| 348 | <MinScale>10000</MinScale> |
| 349 | <MaxScale>1000000000000</MaxScale> |
| 350 | <Rule> |
| 351 | <GeometryType>3</GeometryType> |
| 352 | <ThemeCategory>0</ThemeCategory> |
| 353 | <LegendLabel/> |
| 354 | <Filter/> |
| 355 | <Icon> |
| 356 | <MimeType>image/png</MimeType> |
| 357 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWO8emINAymAiSTVoxpGNQwpDQAvoAJpPgoElwAAAABJRU5ErkJggg==</Content> |
| 358 | </Icon> |
| 359 | </Rule> |
| 360 | </ScaleRange> |
| 361 | </Layer> |
| 362 | </Group> |
| 363 | <Group> |
| 364 | <Name>Municipal</Name> |
| 365 | <LegendLabel>Municipal</LegendLabel> |
| 366 | <ObjectId>eaf58d7e-bbd2-11e2-8001-080027004461</ObjectId> |
| 367 | <DisplayInLegend>true</DisplayInLegend> |
| 368 | <ExpandInLegend>true</ExpandInLegend> |
| 369 | <Visible>true</Visible> |
| 370 | <ActuallyVisible>true</ActuallyVisible> |
| 371 | <Layer> |
| 372 | <Type>1</Type> |
| 373 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</LayerDefinition> |
| 374 | <Name>Districts</Name> |
| 375 | <LegendLabel>Districts</LegendLabel> |
| 376 | <ObjectId>eaf5b48e-bbd2-11e2-8002-080027004461</ObjectId> |
| 377 | <DisplayInLegend>true</DisplayInLegend> |
| 378 | <ExpandInLegend>true</ExpandInLegend> |
| 379 | <Visible>true</Visible> |
| 380 | <ActuallyVisible>false</ActuallyVisible> |
| 381 | <ScaleRange> |
| 382 | <MinScale>10000</MinScale> |
| 383 | <MaxScale>1000000000000</MaxScale> |
| 384 | <Rule> |
| 385 | <GeometryType>3</GeometryType> |
| 386 | <ThemeCategory>0</ThemeCategory> |
| 387 | <LegendLabel/> |
| 388 | <Filter/> |
| 389 | <Icon> |
| 390 | <MimeType>image/png</MimeType> |
| 391 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOUlEQVQokWPcs6JOTFabgTjw6vFVhktHV/4nGlw6upKJSLPhYFTDqAZqaWB59fjq5WOriFT96vFVACkEOt/4XD28AAAAAElFTkSuQmCC</Content> |
| 392 | </Icon> |
| 393 | </Rule> |
| 394 | </ScaleRange> |
| 395 | </Layer> |
| 396 | <Layer> |
| 397 | <Type>1</Type> |
| 398 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</LayerDefinition> |
| 399 | <Name>Buildings</Name> |
| 400 | <LegendLabel>Buildings</LegendLabel> |
| 401 | <ObjectId>eaf5b48e-bbd2-11e2-8003-080027004461</ObjectId> |
| 402 | <DisplayInLegend>true</DisplayInLegend> |
| 403 | <ExpandInLegend>true</ExpandInLegend> |
| 404 | <Visible>true</Visible> |
| 405 | <ActuallyVisible>true</ActuallyVisible> |
| 406 | <ScaleRange> |
| 407 | <MinScale>0</MinScale> |
| 408 | <MaxScale>1500</MaxScale> |
| 409 | <Rule> |
| 410 | <GeometryType>3</GeometryType> |
| 411 | <ThemeCategory>0</ThemeCategory> |
| 412 | <LegendLabel/> |
| 413 | <Filter/> |
| 414 | <Icon> |
| 415 | <MimeType>image/png</MimeType> |
| 416 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWM8evToy5cvGYgD4uLiLC9fvrx06RKRGvT09JiIVAoHoxpGNVBLA4u4uLienh6RqsXFxQHMyAxCMWcM4QAAAABJRU5ErkJggg==</Content> |
| 417 | </Icon> |
| 418 | </Rule> |
| 419 | </ScaleRange> |
| 420 | </Layer> |
| 421 | <Layer> |
| 422 | <Type>1</Type> |
| 423 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</LayerDefinition> |
| 424 | <Name>Parcels</Name> |
| 425 | <LegendLabel>Parcels</LegendLabel> |
| 426 | <ObjectId>eaf5b48e-bbd2-11e2-8004-080027004461</ObjectId> |
| 427 | <DisplayInLegend>true</DisplayInLegend> |
| 428 | <ExpandInLegend>true</ExpandInLegend> |
| 429 | <Visible>true</Visible> |
| 430 | <ActuallyVisible>true</ActuallyVisible> |
| 431 | <ScaleRange> |
| 432 | <MinScale>0</MinScale> |
| 433 | <MaxScale>10000</MaxScale> |
| 434 | <Rule> |
| 435 | <GeometryType>3</GeometryType> |
| 436 | <ThemeCategory>0</ThemeCategory> |
| 437 | <LegendLabel>Zone: AGR</LegendLabel> |
| 438 | <Filter>RTYPE = 'AGR'</Filter> |
| 439 | <Icon> |
| 440 | <MimeType>image/png</MimeType> |
| 441 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWOc0F4lwPGbgTjw4QcriwDHb0X+r0RquM/AzUSkUjgY1TCqgVoaWD78YL3PwE2k6g8/WAEoyAybnvNMrwAAAABJRU5ErkJggg==</Content> |
| 442 | </Icon> |
| 443 | </Rule> |
| 444 | <Rule> |
| 445 | <GeometryType>3</GeometryType> |
| 446 | <ThemeCategory>1</ThemeCategory> |
| 447 | <LegendLabel>Zone: EXM</LegendLabel> |
| 448 | <Filter>RTYPE = 'EXM'</Filter> |
| 449 | <Icon> |
| 450 | <MimeType>image/png</MimeType> |
| 451 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWPs66zh4/rDQBz49I2FhY/rj6zwDyI1PGbgYCJSKRyMahjVQC0NLJ++sTxm4CBS9advLAA9KgyhkvW9tQAAAABJRU5ErkJggg==</Content> |
| 452 | </Icon> |
| 453 | </Rule> |
| 454 | <Rule> |
| 455 | <GeometryType>3</GeometryType> |
| 456 | <ThemeCategory>2</ThemeCategory> |
| 457 | <LegendLabel>Zone: MER</LegendLabel> |
| 458 | <Filter>RTYPE = 'MER'</Filter> |
| 459 | <Icon> |
| 460 | <MimeType>image/png</MimeType> |
| 461 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWPs6a7l5fnHQBz4/IWJhZfnn6T4HyI1MDCwMBGtFApGNYxqoJYGls9fmBgYWIhU/fkLEwC9qwrV+OtROgAAAABJRU5ErkJggg==</Content> |
| 462 | </Icon> |
| 463 | </Rule> |
| 464 | <Rule> |
| 465 | <GeometryType>3</GeometryType> |
| 466 | <ThemeCategory>3</ThemeCategory> |
| 467 | <LegendLabel>Zone: MFG</LegendLabel> |
| 468 | <Filter>RTYPE = 'MFG'</Filter> |
| 469 | <Icon> |
| 470 | <MimeType>image/png</MimeType> |
| 471 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOUlEQVQokWPs6q3n5mMgEnz9xMDCzccgJv2fSA2vGBiZiDUcBkY1jGqglgaWr58YXjEwEqn66ycGAIUGCqdLv0I4AAAAAElFTkSuQmCC</Content> |
| 472 | </Icon> |
| 473 | </Rule> |
| 474 | <Rule> |
| 475 | <GeometryType>3</GeometryType> |
| 476 | <ThemeCategory>4</ThemeCategory> |
| 477 | <LegendLabel>Zone: RES</LegendLabel> |
| 478 | <Filter>RTYPE = 'RES'</Filter> |
| 479 | <Icon> |
| 480 | <MimeType>image/png</MimeType> |
| 481 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAO0lEQVQokWPs7G/kFGBkIA58//CfhVOAUUiemUgN7xj+MhGpFA5GNYxqoJYGlu8f/r9j+Euk6u8f/gMArKMOreezChMAAAAASUVORK5CYII=</Content> |
| 482 | </Icon> |
| 483 | </Rule> |
| 484 | <Rule> |
| 485 | <GeometryType>3</GeometryType> |
| 486 | <ThemeCategory>5</ThemeCategory> |
| 487 | <LegendLabel>Zone: S&W</LegendLabel> |
| 488 | <Filter>RTYPE = 'S&W'</Filter> |
| 489 | <Icon> |
| 490 | <MimeType>image/png</MimeType> |
| 491 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAO0lEQVQokWNsn9jMLsTMQBz4+e4vC7sQM78yG5EaPjL8YiJSKRyMahjVQC0NLD/f/f3I8ItI1T/f/QUAw9kOsaqrjjYAAAAASUVORK5CYII=</Content> |
| 492 | </Icon> |
| 493 | </Rule> |
| 494 | <Rule> |
| 495 | <GeometryType>3</GeometryType> |
| 496 | <ThemeCategory>6</ThemeCategory> |
| 497 | <LegendLabel>Zone: WTC</LegendLabel> |
| 498 | <Filter>RTYPE = 'WTC'</Filter> |
| 499 | <Icon> |
| 500 | <MimeType>image/png</MimeType> |
| 501 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWNsndzCJsLKQBz49eY3C5sIK7c6F5EaGBi+MRGtFApGNYxqoJYGll9vfjMwfCNS9a83vwEcRQzJpppspAAAAABJRU5ErkJggg==</Content> |
| 502 | </Icon> |
| 503 | </Rule> |
| 504 | <Rule> |
| 505 | <GeometryType>3</GeometryType> |
| 506 | <ThemeCategory>7</ThemeCategory> |
| 507 | <LegendLabel>Zone: Other</LegendLabel> |
| 508 | <Filter/> |
| 509 | <Icon> |
| 510 | <MimeType>image/png</MimeType> |
| 511 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAMUlEQVQokWM0NTU1NTVlIA6cPn2axdTUNCsri0gN06ZNYyJSKRyMahjVQC0NjKQmbwAmVgr+9vodNwAAAABJRU5ErkJggg==</Content> |
| 512 | </Icon> |
| 513 | </Rule> |
| 514 | </ScaleRange> |
| 515 | </Layer> |
| 516 | </Group> |
| 517 | <Group> |
| 518 | <Name>Transportation</Name> |
| 519 | <LegendLabel>Transportation</LegendLabel> |
| 520 | <ObjectId>eaf58d7e-bbd2-11e2-8002-080027004461</ObjectId> |
| 521 | <DisplayInLegend>true</DisplayInLegend> |
| 522 | <ExpandInLegend>true</ExpandInLegend> |
| 523 | <Visible>true</Visible> |
| 524 | <ActuallyVisible>true</ActuallyVisible> |
| 525 | <Layer> |
| 526 | <Type>1</Type> |
| 527 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</LayerDefinition> |
| 528 | <Name>Roads</Name> |
| 529 | <LegendLabel>Roads</LegendLabel> |
| 530 | <ObjectId>eaf5b48e-bbd2-11e2-8000-080027004461</ObjectId> |
| 531 | <DisplayInLegend>true</DisplayInLegend> |
| 532 | <ExpandInLegend>true</ExpandInLegend> |
| 533 | <Visible>true</Visible> |
| 534 | <ActuallyVisible>true</ActuallyVisible> |
| 535 | <ScaleRange> |
| 536 | <MinScale>0</MinScale> |
| 537 | <MaxScale>10000</MaxScale> |
| 538 | <Rule> |
| 539 | <GeometryType>2</GeometryType> |
| 540 | <ThemeCategory>0</ThemeCategory> |
| 541 | <LegendLabel/> |
| 542 | <Filter/> |
| 543 | <Icon> |
| 544 | <MimeType>image/png</MimeType> |
| 545 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAIklEQVQokWP8//8/AymAiSTVI1UDS3t7O21tYByNOFpoAAAJdQewcVU/XQAAAABJRU5ErkJggg==</Content> |
| 546 | </Icon> |
| 547 | </Rule> |
| 548 | </ScaleRange> |
| 549 | <ScaleRange> |
| 550 | <MinScale>10000</MinScale> |
| 551 | <MaxScale>24000</MaxScale> |
| 552 | <Rule> |
| 553 | <GeometryType>2</GeometryType> |
| 554 | <ThemeCategory>0</ThemeCategory> |
| 555 | <LegendLabel/> |
| 556 | <Filter/> |
| 557 | <Icon> |
| 558 | <MimeType>image/png</MimeType> |
| 559 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAIklEQVQokWP8//8/AymAiSTVI1UDS3t7O21tYByNOFpoAAAJdQewcVU/XQAAAABJRU5ErkJggg==</Content> |
| 560 | </Icon> |
| 561 | </Rule> |
| 562 | </ScaleRange> |
| 563 | </Layer> |
| 564 | <Layer> |
| 565 | <Type>1</Type> |
| 566 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</LayerDefinition> |
| 567 | <Name>Rail Lines</Name> |
| 568 | <LegendLabel>Rail Lines</LegendLabel> |
| 569 | <ObjectId>eaf5b48e-bbd2-11e2-8001-080027004461</ObjectId> |
| 570 | <DisplayInLegend>true</DisplayInLegend> |
| 571 | <ExpandInLegend>true</ExpandInLegend> |
| 572 | <Visible>false</Visible> |
| 573 | <ActuallyVisible>false</ActuallyVisible> |
| 574 | <ScaleRange> |
| 575 | <MinScale>0</MinScale> |
| 576 | <MaxScale>24000</MaxScale> |
| 577 | <Rule> |
| 578 | <GeometryType>2</GeometryType> |
| 579 | <ThemeCategory>0</ThemeCategory> |
| 580 | <LegendLabel/> |
| 581 | <Filter/> |
| 582 | <Icon> |
| 583 | <MimeType>image/png</MimeType> |
| 584 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAb0lEQVQokc2SwQnAIBAE15AmbMpSfdiIWIR3YAn62Dwur0AECULmtY9ZjoVzJLHCsWR/KIwxSilz1Zy70FqLMc4L5uzfcKaUAIiIiFh+oKoAvPfmrF8IIQCotaqq5TfM2T8aJEn23nPOnGKO+9/zXc8lZ5XdLNzmAAAAAElFTkSuQmCC</Content> |
| 585 | </Icon> |
| 586 | </Rule> |
| 587 | </ScaleRange> |
| 588 | </Layer> |
| 589 | </Group> |
| 590 | </RuntimeMap> |
| 591 | }}} |
| 592 | |
| 593 | REQUESTEDFEATURES = 7 (Basic layer/group structure with inline icons and Feature Source information) |
| 594 | {{{ |
| 595 | <RuntimeMap> |
| 596 | <SiteVersion>2.6.0.0</SiteVersion> |
| 597 | <SessionId>24698672-bbcf-11e2-8000-080027004461_en_MTI3LjAuMC4x0B060B050B04</SessionId> |
| 598 | <Name>Sheboygan</Name> |
| 599 | <MapDefinition>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</MapDefinition> |
| 600 | <CoordinateSystem> |
| 601 | <Wkt>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</Wkt> |
| 602 | <MentorCode>LL84</MentorCode> |
| 603 | <EpsgCode>4326</EpsgCode> |
| 604 | <MetersPerUnit>111319.49079327358</MetersPerUnit> |
| 605 | </CoordinateSystem> |
| 606 | <Extents> |
| 607 | <LowerLeftCoordinate> |
| 608 | <X>-87.764986990962839</X> |
| 609 | <Y>43.691398128787782</Y> |
| 610 | </LowerLeftCoordinate> |
| 611 | <UpperRightCoordinate> |
| 612 | <X>-87.695521510899724</X> |
| 613 | <Y>43.797520000480347</Y> |
| 614 | </UpperRightCoordinate> |
| 615 | </Extents> |
| 616 | <Group> |
| 617 | <Name>Base Map</Name> |
| 618 | <LegendLabel>Base Map</LegendLabel> |
| 619 | <ObjectId>246d570c-bbcf-11e2-8000-080027004461</ObjectId> |
| 620 | <DisplayInLegend>true</DisplayInLegend> |
| 621 | <ExpandInLegend>true</ExpandInLegend> |
| 622 | <Visible>true</Visible> |
| 623 | <ActuallyVisible>true</ActuallyVisible> |
| 624 | <Layer> |
| 625 | <Type>1</Type> |
| 626 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</LayerDefinition> |
| 627 | <Name>Islands</Name> |
| 628 | <LegendLabel>Islands</LegendLabel> |
| 629 | <ObjectId>246da52c-bbcf-11e2-8003-080027004461</ObjectId> |
| 630 | <DisplayInLegend>true</DisplayInLegend> |
| 631 | <ExpandInLegend>true</ExpandInLegend> |
| 632 | <Visible>true</Visible> |
| 633 | <ActuallyVisible>true</ActuallyVisible> |
| 634 | <FeatureSource> |
| 635 | <ResourceId>Library://Samples/Sheboygan/Data/Islands.FeatureSource</ResourceId> |
| 636 | <ClassName>SHP_Schema:Islands</ClassName> |
| 637 | <Geometry>SHPGEOM</Geometry> |
| 638 | </FeatureSource> |
| 639 | <ScaleRange> |
| 640 | <MinScale>0</MinScale> |
| 641 | <MaxScale>1000000000000</MaxScale> |
| 642 | <Rule> |
| 643 | <GeometryType>3</GeometryType> |
| 644 | <ThemeCategory>0</ThemeCategory> |
| 645 | <LegendLabel/> |
| 646 | <Filter/> |
| 647 | <Icon> |
| 648 | <MimeType>image/png</MimeType> |
| 649 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWO8emINAymAiSTVoxpGNQwpDQAvoAJpPgoElwAAAABJRU5ErkJggg==</Content> |
| 650 | </Icon> |
| 651 | </Rule> |
| 652 | </ScaleRange> |
| 653 | </Layer> |
| 654 | <Layer> |
| 655 | <Type>1</Type> |
| 656 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</LayerDefinition> |
| 657 | <Name>Hydrography</Name> |
| 658 | <LegendLabel>Hydrography</LegendLabel> |
| 659 | <ObjectId>246da52c-bbcf-11e2-8004-080027004461</ObjectId> |
| 660 | <DisplayInLegend>true</DisplayInLegend> |
| 661 | <ExpandInLegend>true</ExpandInLegend> |
| 662 | <Visible>true</Visible> |
| 663 | <ActuallyVisible>true</ActuallyVisible> |
| 664 | <FeatureSource> |
| 665 | <ResourceId>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</ResourceId> |
| 666 | <ClassName>SHP_Schema:HydrographicPolygons</ClassName> |
| 667 | <Geometry>SHPGEOM</Geometry> |
| 668 | </FeatureSource> |
| 669 | <ScaleRange> |
| 670 | <MinScale>0</MinScale> |
| 671 | <MaxScale>1000000000000</MaxScale> |
| 672 | <Rule> |
| 673 | <GeometryType>3</GeometryType> |
| 674 | <ThemeCategory>0</ThemeCategory> |
| 675 | <LegendLabel/> |
| 676 | <Filter/> |
| 677 | <Icon> |
| 678 | <MimeType>image/png</MimeType> |
| 679 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWNcffwlAymAiSTVoxpGNQwpDQBmNQJ7CUalHwAAAABJRU5ErkJggg==</Content> |
| 680 | </Icon> |
| 681 | </Rule> |
| 682 | </ScaleRange> |
| 683 | </Layer> |
| 684 | <Layer> |
| 685 | <Type>1</Type> |
| 686 | <LayerDefinition>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</LayerDefinition> |
| 687 | <Name>CityLimits</Name> |
| 688 | <LegendLabel>CityLimits</LegendLabel> |
| 689 | <ObjectId>246da52c-bbcf-11e2-8005-080027004461</ObjectId> |
| 690 | <DisplayInLegend>true</DisplayInLegend> |
| 691 | <ExpandInLegend>true</ExpandInLegend> |
| 692 | <Visible>true</Visible> |
| 693 | <ActuallyVisible>true</ActuallyVisible> |
| 694 | <FeatureSource> |
| 695 | <ResourceId>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</ResourceId> |
| 696 | <ClassName>SHP_Schema:CityLimits</ClassName> |
| 697 | <Geometry>SHPGEOM</Geometry> |
| 698 | </FeatureSource> |
| 699 | <ScaleRange> |
| 700 | <MinScale>0</MinScale> |
| 701 | <MaxScale>10000</MaxScale> |
| 702 | <Rule> |
| 703 | <GeometryType>3</GeometryType> |
| 704 | <ThemeCategory>0</ThemeCategory> |
| 705 | <LegendLabel/> |
| 706 | <Filter/> |
| 707 | <Icon> |
| 708 | <MimeType>image/png</MimeType> |
| 709 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWM8cOAAAymAiSTVoxpGNQwpDQAT+QJghokBTgAAAABJRU5ErkJggg==</Content> |
| 710 | </Icon> |
| 711 | </Rule> |
| 712 | </ScaleRange> |
| 713 | <ScaleRange> |
| 714 | <MinScale>10000</MinScale> |
| 715 | <MaxScale>1000000000000</MaxScale> |
| 716 | <Rule> |
| 717 | <GeometryType>3</GeometryType> |
| 718 | <ThemeCategory>0</ThemeCategory> |
| 719 | <LegendLabel/> |
| 720 | <Filter/> |
| 721 | <Icon> |
| 722 | <MimeType>image/png</MimeType> |
| 723 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWO8emINAymAiSTVoxpGNQwpDQAvoAJpPgoElwAAAABJRU5ErkJggg==</Content> |
| 724 | </Icon> |
| 725 | </Rule> |
| 726 | </ScaleRange> |
| 727 | </Layer> |
| 728 | </Group> |
| 729 | <Group> |
| 730 | <Name>Municipal</Name> |
| 731 | <LegendLabel>Municipal</LegendLabel> |
| 732 | <ObjectId>246d570c-bbcf-11e2-8001-080027004461</ObjectId> |
| 733 | <DisplayInLegend>true</DisplayInLegend> |
| 734 | <ExpandInLegend>true</ExpandInLegend> |
| 735 | <Visible>true</Visible> |
| 736 | <ActuallyVisible>true</ActuallyVisible> |
| 737 | <Layer> |
| 738 | <Type>1</Type> |
| 739 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</LayerDefinition> |
| 740 | <Name>Districts</Name> |
| 741 | <LegendLabel>Districts</LegendLabel> |
| 742 | <ObjectId>246da52c-bbcf-11e2-8000-080027004461</ObjectId> |
| 743 | <DisplayInLegend>true</DisplayInLegend> |
| 744 | <ExpandInLegend>true</ExpandInLegend> |
| 745 | <Visible>true</Visible> |
| 746 | <ActuallyVisible>false</ActuallyVisible> |
| 747 | <FeatureSource> |
| 748 | <ResourceId>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</ResourceId> |
| 749 | <ClassName>SDF_2_Schema:VotingDistricts</ClassName> |
| 750 | <Geometry>Data</Geometry> |
| 751 | </FeatureSource> |
| 752 | <ScaleRange> |
| 753 | <MinScale>10000</MinScale> |
| 754 | <MaxScale>1000000000000</MaxScale> |
| 755 | <Rule> |
| 756 | <GeometryType>3</GeometryType> |
| 757 | <ThemeCategory>0</ThemeCategory> |
| 758 | <LegendLabel/> |
| 759 | <Filter/> |
| 760 | <Icon> |
| 761 | <MimeType>image/png</MimeType> |
| 762 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOUlEQVQokWPcs6JOTFabgTjw6vFVhktHV/4nGlw6upKJSLPhYFTDqAZqaWB59fjq5WOriFT96vFVACkEOt/4XD28AAAAAElFTkSuQmCC</Content> |
| 763 | </Icon> |
| 764 | </Rule> |
| 765 | </ScaleRange> |
| 766 | </Layer> |
| 767 | <Layer> |
| 768 | <Type>1</Type> |
| 769 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</LayerDefinition> |
| 770 | <Name>Buildings</Name> |
| 771 | <LegendLabel>Buildings</LegendLabel> |
| 772 | <ObjectId>246da52c-bbcf-11e2-8001-080027004461</ObjectId> |
| 773 | <DisplayInLegend>true</DisplayInLegend> |
| 774 | <ExpandInLegend>true</ExpandInLegend> |
| 775 | <Visible>true</Visible> |
| 776 | <ActuallyVisible>true</ActuallyVisible> |
| 777 | <FeatureSource> |
| 778 | <ResourceId>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</ResourceId> |
| 779 | <ClassName>SHP_Schema:BuildingOutlines</ClassName> |
| 780 | <Geometry>SHPGEOM</Geometry> |
| 781 | </FeatureSource> |
| 782 | <ScaleRange> |
| 783 | <MinScale>0</MinScale> |
| 784 | <MaxScale>1500</MaxScale> |
| 785 | <Rule> |
| 786 | <GeometryType>3</GeometryType> |
| 787 | <ThemeCategory>0</ThemeCategory> |
| 788 | <LegendLabel/> |
| 789 | <Filter/> |
| 790 | <Icon> |
| 791 | <MimeType>image/png</MimeType> |
| 792 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWM8evToy5cvGYgD4uLiLC9fvrx06RKRGvT09JiIVAoHoxpGNVBLA4u4uLienh6RqsXFxQHMyAxCMWcM4QAAAABJRU5ErkJggg==</Content> |
| 793 | </Icon> |
| 794 | </Rule> |
| 795 | </ScaleRange> |
| 796 | </Layer> |
| 797 | <Layer> |
| 798 | <Type>1</Type> |
| 799 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</LayerDefinition> |
| 800 | <Name>Parcels</Name> |
| 801 | <LegendLabel>Parcels</LegendLabel> |
| 802 | <ObjectId>246da52c-bbcf-11e2-8002-080027004461</ObjectId> |
| 803 | <DisplayInLegend>true</DisplayInLegend> |
| 804 | <ExpandInLegend>true</ExpandInLegend> |
| 805 | <Visible>true</Visible> |
| 806 | <ActuallyVisible>true</ActuallyVisible> |
| 807 | <FeatureSource> |
| 808 | <ResourceId>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</ResourceId> |
| 809 | <ClassName>SHP_Schema:Parcels</ClassName> |
| 810 | <Geometry>SHPGEOM</Geometry> |
| 811 | </FeatureSource> |
| 812 | <ScaleRange> |
| 813 | <MinScale>0</MinScale> |
| 814 | <MaxScale>10000</MaxScale> |
| 815 | <Rule> |
| 816 | <GeometryType>3</GeometryType> |
| 817 | <ThemeCategory>0</ThemeCategory> |
| 818 | <LegendLabel>Zone: AGR</LegendLabel> |
| 819 | <Filter>RTYPE = 'AGR'</Filter> |
| 820 | <Icon> |
| 821 | <MimeType>image/png</MimeType> |
| 822 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWOc0F4lwPGbgTjw4QcriwDHb0X+r0RquM/AzUSkUjgY1TCqgVoaWD78YL3PwE2k6g8/WAEoyAybnvNMrwAAAABJRU5ErkJggg==</Content> |
| 823 | </Icon> |
| 824 | </Rule> |
| 825 | <Rule> |
| 826 | <GeometryType>3</GeometryType> |
| 827 | <ThemeCategory>1</ThemeCategory> |
| 828 | <LegendLabel>Zone: EXM</LegendLabel> |
| 829 | <Filter>RTYPE = 'EXM'</Filter> |
| 830 | <Icon> |
| 831 | <MimeType>image/png</MimeType> |
| 832 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWPs66zh4/rDQBz49I2FhY/rj6zwDyI1PGbgYCJSKRyMahjVQC0NLJ++sTxm4CBS9advLAA9KgyhkvW9tQAAAABJRU5ErkJggg==</Content> |
| 833 | </Icon> |
| 834 | </Rule> |
| 835 | <Rule> |
| 836 | <GeometryType>3</GeometryType> |
| 837 | <ThemeCategory>2</ThemeCategory> |
| 838 | <LegendLabel>Zone: MER</LegendLabel> |
| 839 | <Filter>RTYPE = 'MER'</Filter> |
| 840 | <Icon> |
| 841 | <MimeType>image/png</MimeType> |
| 842 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWPs6a7l5fnHQBz4/IWJhZfnn6T4HyI1MDCwMBGtFApGNYxqoJYGls9fmBgYWIhU/fkLEwC9qwrV+OtROgAAAABJRU5ErkJggg==</Content> |
| 843 | </Icon> |
| 844 | </Rule> |
| 845 | <Rule> |
| 846 | <GeometryType>3</GeometryType> |
| 847 | <ThemeCategory>3</ThemeCategory> |
| 848 | <LegendLabel>Zone: MFG</LegendLabel> |
| 849 | <Filter>RTYPE = 'MFG'</Filter> |
| 850 | <Icon> |
| 851 | <MimeType>image/png</MimeType> |
| 852 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOUlEQVQokWPs6q3n5mMgEnz9xMDCzccgJv2fSA2vGBiZiDUcBkY1jGqglgaWr58YXjEwEqn66ycGAIUGCqdLv0I4AAAAAElFTkSuQmCC</Content> |
| 853 | </Icon> |
| 854 | </Rule> |
| 855 | <Rule> |
| 856 | <GeometryType>3</GeometryType> |
| 857 | <ThemeCategory>4</ThemeCategory> |
| 858 | <LegendLabel>Zone: RES</LegendLabel> |
| 859 | <Filter>RTYPE = 'RES'</Filter> |
| 860 | <Icon> |
| 861 | <MimeType>image/png</MimeType> |
| 862 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAO0lEQVQokWPs7G/kFGBkIA58//CfhVOAUUiemUgN7xj+MhGpFA5GNYxqoJYGlu8f/r9j+Euk6u8f/gMArKMOreezChMAAAAASUVORK5CYII=</Content> |
| 863 | </Icon> |
| 864 | </Rule> |
| 865 | <Rule> |
| 866 | <GeometryType>3</GeometryType> |
| 867 | <ThemeCategory>5</ThemeCategory> |
| 868 | <LegendLabel>Zone: S&W</LegendLabel> |
| 869 | <Filter>RTYPE = 'S&W'</Filter> |
| 870 | <Icon> |
| 871 | <MimeType>image/png</MimeType> |
| 872 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAO0lEQVQokWNsn9jMLsTMQBz4+e4vC7sQM78yG5EaPjL8YiJSKRyMahjVQC0NLD/f/f3I8ItI1T/f/QUAw9kOsaqrjjYAAAAASUVORK5CYII=</Content> |
| 873 | </Icon> |
| 874 | </Rule> |
| 875 | <Rule> |
| 876 | <GeometryType>3</GeometryType> |
| 877 | <ThemeCategory>6</ThemeCategory> |
| 878 | <LegendLabel>Zone: WTC</LegendLabel> |
| 879 | <Filter>RTYPE = 'WTC'</Filter> |
| 880 | <Icon> |
| 881 | <MimeType>image/png</MimeType> |
| 882 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWNsndzCJsLKQBz49eY3C5sIK7c6F5EaGBi+MRGtFApGNYxqoJYGll9vfjMwfCNS9a83vwEcRQzJpppspAAAAABJRU5ErkJggg==</Content> |
| 883 | </Icon> |
| 884 | </Rule> |
| 885 | <Rule> |
| 886 | <GeometryType>3</GeometryType> |
| 887 | <ThemeCategory>7</ThemeCategory> |
| 888 | <LegendLabel>Zone: Other</LegendLabel> |
| 889 | <Filter/> |
| 890 | <Icon> |
| 891 | <MimeType>image/png</MimeType> |
| 892 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAMUlEQVQokWM0NTU1NTVlIA6cPn2axdTUNCsri0gN06ZNYyJSKRyMahjVQC0NjKQmbwAmVgr+9vodNwAAAABJRU5ErkJggg==</Content> |
| 893 | </Icon> |
| 894 | </Rule> |
| 895 | </ScaleRange> |
| 896 | </Layer> |
| 897 | </Group> |
| 898 | <Group> |
| 899 | <Name>Transportation</Name> |
| 900 | <LegendLabel>Transportation</LegendLabel> |
| 901 | <ObjectId>246d570c-bbcf-11e2-8002-080027004461</ObjectId> |
| 902 | <DisplayInLegend>true</DisplayInLegend> |
| 903 | <ExpandInLegend>true</ExpandInLegend> |
| 904 | <Visible>true</Visible> |
| 905 | <ActuallyVisible>true</ActuallyVisible> |
| 906 | <Layer> |
| 907 | <Type>1</Type> |
| 908 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</LayerDefinition> |
| 909 | <Name>Roads</Name> |
| 910 | <LegendLabel>Roads</LegendLabel> |
| 911 | <ObjectId>246d7e1c-bbcf-11e2-8000-080027004461</ObjectId> |
| 912 | <DisplayInLegend>true</DisplayInLegend> |
| 913 | <ExpandInLegend>true</ExpandInLegend> |
| 914 | <Visible>true</Visible> |
| 915 | <ActuallyVisible>true</ActuallyVisible> |
| 916 | <FeatureSource> |
| 917 | <ResourceId>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</ResourceId> |
| 918 | <ClassName>SHP_Schema:RoadCenterLines</ClassName> |
| 919 | <Geometry>SHPGEOM</Geometry> |
| 920 | </FeatureSource> |
| 921 | <ScaleRange> |
| 922 | <MinScale>0</MinScale> |
| 923 | <MaxScale>10000</MaxScale> |
| 924 | <Rule> |
| 925 | <GeometryType>2</GeometryType> |
| 926 | <ThemeCategory>0</ThemeCategory> |
| 927 | <LegendLabel/> |
| 928 | <Filter/> |
| 929 | <Icon> |
| 930 | <MimeType>image/png</MimeType> |
| 931 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAIklEQVQokWP8//8/AymAiSTVI1UDS3t7O21tYByNOFpoAAAJdQewcVU/XQAAAABJRU5ErkJggg==</Content> |
| 932 | </Icon> |
| 933 | </Rule> |
| 934 | </ScaleRange> |
| 935 | <ScaleRange> |
| 936 | <MinScale>10000</MinScale> |
| 937 | <MaxScale>24000</MaxScale> |
| 938 | <Rule> |
| 939 | <GeometryType>2</GeometryType> |
| 940 | <ThemeCategory>0</ThemeCategory> |
| 941 | <LegendLabel/> |
| 942 | <Filter/> |
| 943 | <Icon> |
| 944 | <MimeType>image/png</MimeType> |
| 945 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAIklEQVQokWP8//8/AymAiSTVI1UDS3t7O21tYByNOFpoAAAJdQewcVU/XQAAAABJRU5ErkJggg==</Content> |
| 946 | </Icon> |
| 947 | </Rule> |
| 948 | </ScaleRange> |
| 949 | </Layer> |
| 950 | <Layer> |
| 951 | <Type>1</Type> |
| 952 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</LayerDefinition> |
| 953 | <Name>Rail Lines</Name> |
| 954 | <LegendLabel>Rail Lines</LegendLabel> |
| 955 | <ObjectId>246d7e1c-bbcf-11e2-8001-080027004461</ObjectId> |
| 956 | <DisplayInLegend>true</DisplayInLegend> |
| 957 | <ExpandInLegend>true</ExpandInLegend> |
| 958 | <Visible>false</Visible> |
| 959 | <ActuallyVisible>false</ActuallyVisible> |
| 960 | <FeatureSource> |
| 961 | <ResourceId>Library://Samples/Sheboygan/Data/Rail.FeatureSource</ResourceId> |
| 962 | <ClassName>SHP_Schema:Rail</ClassName> |
| 963 | <Geometry>SHPGEOM</Geometry> |
| 964 | </FeatureSource> |
| 965 | <ScaleRange> |
| 966 | <MinScale>0</MinScale> |
| 967 | <MaxScale>24000</MaxScale> |
| 968 | <Rule> |
| 969 | <GeometryType>2</GeometryType> |
| 970 | <ThemeCategory>0</ThemeCategory> |
| 971 | <LegendLabel/> |
| 972 | <Filter/> |
| 973 | <Icon> |
| 974 | <MimeType>image/png</MimeType> |
| 975 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAb0lEQVQokc2SwQnAIBAE15AmbMpSfdiIWIR3YAn62Dwur0AECULmtY9ZjoVzJLHCsWR/KIwxSilz1Zy70FqLMc4L5uzfcKaUAIiIiFh+oKoAvPfmrF8IIQCotaqq5TfM2T8aJEn23nPOnGKO+9/zXc8lZ5XdLNzmAAAAAElFTkSuQmCC</Content> |
| 976 | </Icon> |
| 977 | </Rule> |
| 978 | </ScaleRange> |
| 979 | </Layer> |
| 980 | </Group> |
| 981 | </RuntimeMap> |
| 982 | }}} |
| 983 | |
| 984 | REQUESTEDFEATURES = 7 and ICONSPERSCALERANGE = 3 (Observe the theme rules of the Parcels. It is assumed client applications uses this lack of icons as a "hint" to compress the theme when displaying in an interactive legend control) |
| 985 | {{{ |
| 986 | <RuntimeMap> |
| 987 | <SiteVersion>2.6.0.0</SiteVersion> |
| 988 | <SessionId>63ab622e-bbcf-11e2-8000-080027004461_en_MTI3LjAuMC4x0B060B050B04</SessionId> |
| 989 | <Name>Sheboygan</Name> |
| 990 | <MapDefinition>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</MapDefinition> |
| 991 | <CoordinateSystem> |
| 992 | <Wkt>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</Wkt> |
| 993 | <MentorCode>LL84</MentorCode> |
| 994 | <EpsgCode>4326</EpsgCode> |
| 995 | <MetersPerUnit>111319.49079327358</MetersPerUnit> |
| 996 | </CoordinateSystem> |
| 997 | <Extents> |
| 998 | <LowerLeftCoordinate> |
| 999 | <X>-87.764986990962839</X> |
| 1000 | <Y>43.691398128787782</Y> |
| 1001 | </LowerLeftCoordinate> |
| 1002 | <UpperRightCoordinate> |
| 1003 | <X>-87.695521510899724</X> |
| 1004 | <Y>43.797520000480347</Y> |
| 1005 | </UpperRightCoordinate> |
| 1006 | </Extents> |
| 1007 | <Group> |
| 1008 | <Name>Base Map</Name> |
| 1009 | <LegendLabel>Base Map</LegendLabel> |
| 1010 | <ObjectId>63af0bb8-bbcf-11e2-8001-080027004461</ObjectId> |
| 1011 | <DisplayInLegend>true</DisplayInLegend> |
| 1012 | <ExpandInLegend>true</ExpandInLegend> |
| 1013 | <Visible>true</Visible> |
| 1014 | <ActuallyVisible>true</ActuallyVisible> |
| 1015 | <Layer> |
| 1016 | <Type>1</Type> |
| 1017 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</LayerDefinition> |
| 1018 | <Name>Islands</Name> |
| 1019 | <LegendLabel>Islands</LegendLabel> |
| 1020 | <ObjectId>63af59d8-bbcf-11e2-8004-080027004461</ObjectId> |
| 1021 | <DisplayInLegend>true</DisplayInLegend> |
| 1022 | <ExpandInLegend>true</ExpandInLegend> |
| 1023 | <Visible>true</Visible> |
| 1024 | <ActuallyVisible>true</ActuallyVisible> |
| 1025 | <FeatureSource> |
| 1026 | <ResourceId>Library://Samples/Sheboygan/Data/Islands.FeatureSource</ResourceId> |
| 1027 | <ClassName>SHP_Schema:Islands</ClassName> |
| 1028 | <Geometry>SHPGEOM</Geometry> |
| 1029 | </FeatureSource> |
| 1030 | <ScaleRange> |
| 1031 | <MinScale>0</MinScale> |
| 1032 | <MaxScale>1000000000000</MaxScale> |
| 1033 | <Rule> |
| 1034 | <GeometryType>3</GeometryType> |
| 1035 | <ThemeCategory>0</ThemeCategory> |
| 1036 | <LegendLabel/> |
| 1037 | <Filter/> |
| 1038 | <Icon> |
| 1039 | <MimeType>image/png</MimeType> |
| 1040 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWO8emINAymAiSTVoxpGNQwpDQAvoAJpPgoElwAAAABJRU5ErkJggg==</Content> |
| 1041 | </Icon> |
| 1042 | </Rule> |
| 1043 | </ScaleRange> |
| 1044 | </Layer> |
| 1045 | <Layer> |
| 1046 | <Type>1</Type> |
| 1047 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</LayerDefinition> |
| 1048 | <Name>Hydrography</Name> |
| 1049 | <LegendLabel>Hydrography</LegendLabel> |
| 1050 | <ObjectId>63af59d8-bbcf-11e2-8005-080027004461</ObjectId> |
| 1051 | <DisplayInLegend>true</DisplayInLegend> |
| 1052 | <ExpandInLegend>true</ExpandInLegend> |
| 1053 | <Visible>true</Visible> |
| 1054 | <ActuallyVisible>true</ActuallyVisible> |
| 1055 | <FeatureSource> |
| 1056 | <ResourceId>Library://Samples/Sheboygan/Data/HydrographicPolygons.FeatureSource</ResourceId> |
| 1057 | <ClassName>SHP_Schema:HydrographicPolygons</ClassName> |
| 1058 | <Geometry>SHPGEOM</Geometry> |
| 1059 | </FeatureSource> |
| 1060 | <ScaleRange> |
| 1061 | <MinScale>0</MinScale> |
| 1062 | <MaxScale>1000000000000</MaxScale> |
| 1063 | <Rule> |
| 1064 | <GeometryType>3</GeometryType> |
| 1065 | <ThemeCategory>0</ThemeCategory> |
| 1066 | <LegendLabel/> |
| 1067 | <Filter/> |
| 1068 | <Icon> |
| 1069 | <MimeType>image/png</MimeType> |
| 1070 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWNcffwlAymAiSTVoxpGNQwpDQBmNQJ7CUalHwAAAABJRU5ErkJggg==</Content> |
| 1071 | </Icon> |
| 1072 | </Rule> |
| 1073 | </ScaleRange> |
| 1074 | </Layer> |
| 1075 | <Layer> |
| 1076 | <Type>1</Type> |
| 1077 | <LayerDefinition>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</LayerDefinition> |
| 1078 | <Name>CityLimits</Name> |
| 1079 | <LegendLabel>CityLimits</LegendLabel> |
| 1080 | <ObjectId>63af59d8-bbcf-11e2-8006-080027004461</ObjectId> |
| 1081 | <DisplayInLegend>true</DisplayInLegend> |
| 1082 | <ExpandInLegend>true</ExpandInLegend> |
| 1083 | <Visible>true</Visible> |
| 1084 | <ActuallyVisible>true</ActuallyVisible> |
| 1085 | <FeatureSource> |
| 1086 | <ResourceId>Library://Samples/Sheboygan/Data/CityLimits.FeatureSource</ResourceId> |
| 1087 | <ClassName>SHP_Schema:CityLimits</ClassName> |
| 1088 | <Geometry>SHPGEOM</Geometry> |
| 1089 | </FeatureSource> |
| 1090 | <ScaleRange> |
| 1091 | <MinScale>0</MinScale> |
| 1092 | <MaxScale>10000</MaxScale> |
| 1093 | <Rule> |
| 1094 | <GeometryType>3</GeometryType> |
| 1095 | <ThemeCategory>0</ThemeCategory> |
| 1096 | <LegendLabel/> |
| 1097 | <Filter/> |
| 1098 | <Icon> |
| 1099 | <MimeType>image/png</MimeType> |
| 1100 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWM8cOAAAymAiSTVoxpGNQwpDQAT+QJghokBTgAAAABJRU5ErkJggg==</Content> |
| 1101 | </Icon> |
| 1102 | </Rule> |
| 1103 | </ScaleRange> |
| 1104 | <ScaleRange> |
| 1105 | <MinScale>10000</MinScale> |
| 1106 | <MaxScale>1000000000000</MaxScale> |
| 1107 | <Rule> |
| 1108 | <GeometryType>3</GeometryType> |
| 1109 | <ThemeCategory>0</ThemeCategory> |
| 1110 | <LegendLabel/> |
| 1111 | <Filter/> |
| 1112 | <Icon> |
| 1113 | <MimeType>image/png</MimeType> |
| 1114 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAGUlEQVQokWO8emINAymAiSTVoxpGNQwpDQAvoAJpPgoElwAAAABJRU5ErkJggg==</Content> |
| 1115 | </Icon> |
| 1116 | </Rule> |
| 1117 | </ScaleRange> |
| 1118 | </Layer> |
| 1119 | </Group> |
| 1120 | <Group> |
| 1121 | <Name>Municipal</Name> |
| 1122 | <LegendLabel>Municipal</LegendLabel> |
| 1123 | <ObjectId>63af0bb8-bbcf-11e2-8002-080027004461</ObjectId> |
| 1124 | <DisplayInLegend>true</DisplayInLegend> |
| 1125 | <ExpandInLegend>true</ExpandInLegend> |
| 1126 | <Visible>true</Visible> |
| 1127 | <ActuallyVisible>true</ActuallyVisible> |
| 1128 | <Layer> |
| 1129 | <Type>1</Type> |
| 1130 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</LayerDefinition> |
| 1131 | <Name>Districts</Name> |
| 1132 | <LegendLabel>Districts</LegendLabel> |
| 1133 | <ObjectId>63af59d8-bbcf-11e2-8001-080027004461</ObjectId> |
| 1134 | <DisplayInLegend>true</DisplayInLegend> |
| 1135 | <ExpandInLegend>true</ExpandInLegend> |
| 1136 | <Visible>true</Visible> |
| 1137 | <ActuallyVisible>false</ActuallyVisible> |
| 1138 | <FeatureSource> |
| 1139 | <ResourceId>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</ResourceId> |
| 1140 | <ClassName>SDF_2_Schema:VotingDistricts</ClassName> |
| 1141 | <Geometry>Data</Geometry> |
| 1142 | </FeatureSource> |
| 1143 | <ScaleRange> |
| 1144 | <MinScale>10000</MinScale> |
| 1145 | <MaxScale>1000000000000</MaxScale> |
| 1146 | <Rule> |
| 1147 | <GeometryType>3</GeometryType> |
| 1148 | <ThemeCategory>0</ThemeCategory> |
| 1149 | <LegendLabel/> |
| 1150 | <Filter/> |
| 1151 | <Icon> |
| 1152 | <MimeType>image/png</MimeType> |
| 1153 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOUlEQVQokWPcs6JOTFabgTjw6vFVhktHV/4nGlw6upKJSLPhYFTDqAZqaWB59fjq5WOriFT96vFVACkEOt/4XD28AAAAAElFTkSuQmCC</Content> |
| 1154 | </Icon> |
| 1155 | </Rule> |
| 1156 | </ScaleRange> |
| 1157 | </Layer> |
| 1158 | <Layer> |
| 1159 | <Type>1</Type> |
| 1160 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</LayerDefinition> |
| 1161 | <Name>Buildings</Name> |
| 1162 | <LegendLabel>Buildings</LegendLabel> |
| 1163 | <ObjectId>63af59d8-bbcf-11e2-8002-080027004461</ObjectId> |
| 1164 | <DisplayInLegend>true</DisplayInLegend> |
| 1165 | <ExpandInLegend>true</ExpandInLegend> |
| 1166 | <Visible>true</Visible> |
| 1167 | <ActuallyVisible>true</ActuallyVisible> |
| 1168 | <FeatureSource> |
| 1169 | <ResourceId>Library://Samples/Sheboygan/Data/BuildingOutlines.FeatureSource</ResourceId> |
| 1170 | <ClassName>SHP_Schema:BuildingOutlines</ClassName> |
| 1171 | <Geometry>SHPGEOM</Geometry> |
| 1172 | </FeatureSource> |
| 1173 | <ScaleRange> |
| 1174 | <MinScale>0</MinScale> |
| 1175 | <MaxScale>1500</MaxScale> |
| 1176 | <Rule> |
| 1177 | <GeometryType>3</GeometryType> |
| 1178 | <ThemeCategory>0</ThemeCategory> |
| 1179 | <LegendLabel/> |
| 1180 | <Filter/> |
| 1181 | <Icon> |
| 1182 | <MimeType>image/png</MimeType> |
| 1183 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWM8evToy5cvGYgD4uLiLC9fvrx06RKRGvT09JiIVAoHoxpGNVBLA4u4uLienh6RqsXFxQHMyAxCMWcM4QAAAABJRU5ErkJggg==</Content> |
| 1184 | </Icon> |
| 1185 | </Rule> |
| 1186 | </ScaleRange> |
| 1187 | </Layer> |
| 1188 | <Layer> |
| 1189 | <Type>1</Type> |
| 1190 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</LayerDefinition> |
| 1191 | <Name>Parcels</Name> |
| 1192 | <LegendLabel>Parcels</LegendLabel> |
| 1193 | <ObjectId>63af59d8-bbcf-11e2-8003-080027004461</ObjectId> |
| 1194 | <DisplayInLegend>true</DisplayInLegend> |
| 1195 | <ExpandInLegend>true</ExpandInLegend> |
| 1196 | <Visible>true</Visible> |
| 1197 | <ActuallyVisible>true</ActuallyVisible> |
| 1198 | <FeatureSource> |
| 1199 | <ResourceId>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</ResourceId> |
| 1200 | <ClassName>SHP_Schema:Parcels</ClassName> |
| 1201 | <Geometry>SHPGEOM</Geometry> |
| 1202 | </FeatureSource> |
| 1203 | <ScaleRange> |
| 1204 | <MinScale>0</MinScale> |
| 1205 | <MaxScale>10000</MaxScale> |
| 1206 | <Rule> |
| 1207 | <GeometryType>3</GeometryType> |
| 1208 | <ThemeCategory>0</ThemeCategory> |
| 1209 | <LegendLabel>Zone: AGR</LegendLabel> |
| 1210 | <Filter>RTYPE = 'AGR'</Filter> |
| 1211 | <Icon> |
| 1212 | <MimeType>image/png</MimeType> |
| 1213 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAOklEQVQokWOc0F4lwPGbgTjw4QcriwDHb0X+r0RquM/AzUSkUjgY1TCqgVoaWD78YL3PwE2k6g8/WAEoyAybnvNMrwAAAABJRU5ErkJggg==</Content> |
| 1214 | </Icon> |
| 1215 | </Rule> |
| 1216 | <Rule> |
| 1217 | <GeometryType>3</GeometryType> |
| 1218 | <ThemeCategory>1</ThemeCategory> |
| 1219 | <LegendLabel>Zone: EXM</LegendLabel> |
| 1220 | <Filter>RTYPE = 'EXM'</Filter> |
| 1221 | </Rule> |
| 1222 | <Rule> |
| 1223 | <GeometryType>3</GeometryType> |
| 1224 | <ThemeCategory>2</ThemeCategory> |
| 1225 | <LegendLabel>Zone: MER</LegendLabel> |
| 1226 | <Filter>RTYPE = 'MER'</Filter> |
| 1227 | </Rule> |
| 1228 | <Rule> |
| 1229 | <GeometryType>3</GeometryType> |
| 1230 | <ThemeCategory>3</ThemeCategory> |
| 1231 | <LegendLabel>Zone: MFG</LegendLabel> |
| 1232 | <Filter>RTYPE = 'MFG'</Filter> |
| 1233 | </Rule> |
| 1234 | <Rule> |
| 1235 | <GeometryType>3</GeometryType> |
| 1236 | <ThemeCategory>4</ThemeCategory> |
| 1237 | <LegendLabel>Zone: RES</LegendLabel> |
| 1238 | <Filter>RTYPE = 'RES'</Filter> |
| 1239 | </Rule> |
| 1240 | <Rule> |
| 1241 | <GeometryType>3</GeometryType> |
| 1242 | <ThemeCategory>5</ThemeCategory> |
| 1243 | <LegendLabel>Zone: S&W</LegendLabel> |
| 1244 | <Filter>RTYPE = 'S&W'</Filter> |
| 1245 | </Rule> |
| 1246 | <Rule> |
| 1247 | <GeometryType>3</GeometryType> |
| 1248 | <ThemeCategory>6</ThemeCategory> |
| 1249 | <LegendLabel>Zone: WTC</LegendLabel> |
| 1250 | <Filter>RTYPE = 'WTC'</Filter> |
| 1251 | </Rule> |
| 1252 | <Rule> |
| 1253 | <GeometryType>3</GeometryType> |
| 1254 | <ThemeCategory>7</ThemeCategory> |
| 1255 | <LegendLabel>Zone: Other</LegendLabel> |
| 1256 | <Filter/> |
| 1257 | <Icon> |
| 1258 | <MimeType>image/png</MimeType> |
| 1259 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAMUlEQVQokWM0NTU1NTVlIA6cPn2axdTUNCsri0gN06ZNYyJSKRyMahjVQC0NjKQmbwAmVgr+9vodNwAAAABJRU5ErkJggg==</Content> |
| 1260 | </Icon> |
| 1261 | </Rule> |
| 1262 | </ScaleRange> |
| 1263 | </Layer> |
| 1264 | </Group> |
| 1265 | <Group> |
| 1266 | <Name>Transportation</Name> |
| 1267 | <LegendLabel>Transportation</LegendLabel> |
| 1268 | <ObjectId>63af0bb8-bbcf-11e2-8003-080027004461</ObjectId> |
| 1269 | <DisplayInLegend>true</DisplayInLegend> |
| 1270 | <ExpandInLegend>true</ExpandInLegend> |
| 1271 | <Visible>true</Visible> |
| 1272 | <ActuallyVisible>true</ActuallyVisible> |
| 1273 | <Layer> |
| 1274 | <Type>1</Type> |
| 1275 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</LayerDefinition> |
| 1276 | <Name>Roads</Name> |
| 1277 | <LegendLabel>Roads</LegendLabel> |
| 1278 | <ObjectId>63af32c8-bbcf-11e2-8000-080027004461</ObjectId> |
| 1279 | <DisplayInLegend>true</DisplayInLegend> |
| 1280 | <ExpandInLegend>true</ExpandInLegend> |
| 1281 | <Visible>true</Visible> |
| 1282 | <ActuallyVisible>true</ActuallyVisible> |
| 1283 | <FeatureSource> |
| 1284 | <ResourceId>Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource</ResourceId> |
| 1285 | <ClassName>SHP_Schema:RoadCenterLines</ClassName> |
| 1286 | <Geometry>SHPGEOM</Geometry> |
| 1287 | </FeatureSource> |
| 1288 | <ScaleRange> |
| 1289 | <MinScale>0</MinScale> |
| 1290 | <MaxScale>10000</MaxScale> |
| 1291 | <Rule> |
| 1292 | <GeometryType>2</GeometryType> |
| 1293 | <ThemeCategory>0</ThemeCategory> |
| 1294 | <LegendLabel/> |
| 1295 | <Filter/> |
| 1296 | <Icon> |
| 1297 | <MimeType>image/png</MimeType> |
| 1298 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAIklEQVQokWP8//8/AymAiSTVI1UDS3t7O21tYByNOFpoAAAJdQewcVU/XQAAAABJRU5ErkJggg==</Content> |
| 1299 | </Icon> |
| 1300 | </Rule> |
| 1301 | </ScaleRange> |
| 1302 | <ScaleRange> |
| 1303 | <MinScale>10000</MinScale> |
| 1304 | <MaxScale>24000</MaxScale> |
| 1305 | <Rule> |
| 1306 | <GeometryType>2</GeometryType> |
| 1307 | <ThemeCategory>0</ThemeCategory> |
| 1308 | <LegendLabel/> |
| 1309 | <Filter/> |
| 1310 | <Icon> |
| 1311 | <MimeType>image/png</MimeType> |
| 1312 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAIklEQVQokWP8//8/AymAiSTVI1UDS3t7O21tYByNOFpoAAAJdQewcVU/XQAAAABJRU5ErkJggg==</Content> |
| 1313 | </Icon> |
| 1314 | </Rule> |
| 1315 | </ScaleRange> |
| 1316 | </Layer> |
| 1317 | <Layer> |
| 1318 | <Type>1</Type> |
| 1319 | <LayerDefinition>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</LayerDefinition> |
| 1320 | <Name>Rail Lines</Name> |
| 1321 | <LegendLabel>Rail Lines</LegendLabel> |
| 1322 | <ObjectId>63af59d8-bbcf-11e2-8000-080027004461</ObjectId> |
| 1323 | <DisplayInLegend>true</DisplayInLegend> |
| 1324 | <ExpandInLegend>true</ExpandInLegend> |
| 1325 | <Visible>false</Visible> |
| 1326 | <ActuallyVisible>false</ActuallyVisible> |
| 1327 | <FeatureSource> |
| 1328 | <ResourceId>Library://Samples/Sheboygan/Data/Rail.FeatureSource</ResourceId> |
| 1329 | <ClassName>SHP_Schema:Rail</ClassName> |
| 1330 | <Geometry>SHPGEOM</Geometry> |
| 1331 | </FeatureSource> |
| 1332 | <ScaleRange> |
| 1333 | <MinScale>0</MinScale> |
| 1334 | <MaxScale>24000</MaxScale> |
| 1335 | <Rule> |
| 1336 | <GeometryType>2</GeometryType> |
| 1337 | <ThemeCategory>0</ThemeCategory> |
| 1338 | <LegendLabel/> |
| 1339 | <Filter/> |
| 1340 | <Icon> |
| 1341 | <MimeType>image/png</MimeType> |
| 1342 | <Content>iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAACQkWg2AAAAA3NCSVQICAjb4U/gAAAAb0lEQVQokc2SwQnAIBAE15AmbMpSfdiIWIR3YAn62Dwur0AECULmtY9ZjoVzJLHCsWR/KIwxSilz1Zy70FqLMc4L5uzfcKaUAIiIiFh+oKoAvPfmrF8IIQCotaqq5TfM2T8aJEn23nPOnGKO+9/zXc8lZ5XdLNzmAAAAAElFTkSuQmCC</Content> |
| 1343 | </Icon> |
| 1344 | </Rule> |
| 1345 | </ScaleRange> |
| 1346 | </Layer> |
| 1347 | </Group> |
| 1348 | </RuntimeMap> |
| 1349 | }}} |
| 1350 | |
| 1351 | == Implications == |
| 1352 | |
| 1353 | This is a brand new API. There are no compatibility issues. |
| 1354 | |
| 1355 | == Test Plan == |
| 1356 | |
| 1357 | Test the operation with various requested feature levels against a pure OpenLayers map viewer. |
| 1358 | |
| 1359 | Test and verify CREATERUNTIMEMAP at full feature level provides all the necessary information for Fusion to bypass LoadMap.php and LoadScaleRanges.php |
| 1360 | |
| 1361 | == Funding / Resources == |
| 1362 | |
| 1363 | Community |
