Changes between Version 60 and Version 61 of MapGuideRfc14
05/10/07 02:45:59 (18 years ago)
waltweltonlair
Updated list of changes made
  • MapGuideRfc14
    v60 v61
    6868    </Image>
    6969    <Text>
    70       <String>%INTERSTATE_NUMBER%</String>
     70      <Content>%INTERSTATE_NUMBER%</Content>
    7171      <FontName>'Arial'</FontName>
    7272      <Height>6</Height>
    187187        </Path>
    188188        <Text>
    189           <String>'GAS'</String>
     189          <Content>'GAS'</Content>
    190190          <FontName>'Arial'</FontName>
    191191          <Height>3.5</Height>
    339339    <Text>
    340340      <ResizeControl>'AddToResizeBox'</ResizeControl>
    341       <String>%INTERSTATE_NUMBER%</String>
     341      <Content>%INTERSTATE_NUMBER%</Content>
    342342      <FontName>'Arial'</FontName>
    343343      <Height>6</Height>
    349349  </Graphics>
    350350  <ResizeBox>
     351    <SizeX>6</SizeX>
     352    <SizeY>5</SizeY>
    351353    <PositionX>0</PositionX>
    352354    <PositionY>0</PositionY>
    353     <SizeX>6</SizeX>
    354     <SizeY>5</SizeY>
    355355    <GrowControl>'GrowInX'</GrowControl>
    356356  </ResizeBox>
    419419      <DisplayName>Line Weight</DisplayName>
    420420      <Description>The line weight for the symbol</Description>
    421       <ValueList>
     421      <AllowedValues>
    422422        <Value>1</Value>
    423423        <Value>2</Value>
    424424        <Value>3</Value>
    425425        <Value>4</Value>
    426       </ValueList>
     426      </AllowedValues>
    427427    </Parameter>
    428428  </ParameterDefinition>
    442442      <DisplayName>Linien Dicke<DisplayName>
    443443      <Description>Das ist nur ein Beispiel.</Description>
    444       <ValueList>
     444      <AllowedValues>
    445445        <Value>1</Value>
    446446        <Value>2</Value>
    447447        <Value>3</Value>
    448448        <Value>4</Value>
    449       </ValueList>
     449      </AllowedValues>
    450450    </Parameter>
    451451  </ParameterDefinition>
    547547== Addendum, April 1, 2007 ==
    548548
    549 Updated schemas per ticket #21.
     549Updated schemas per ticket #21 (Change new symbolization !SymbolReference elements to !ResourceId for indexing).
    550550
    551551== Addendum, April 3, 2007 ==
    552552
    553 Updated !SymbolDefinition schema per ticket #27.
     553Updated !SymbolDefinition schema per ticket #27 (Schema does not allow setting resource ID for referenced content in Image graphic element).
     554
     555== Addendum, April 12, 2007 ==
     556
     557Renamed the '!NoOverlap' !VertexControl option to '!OverlapNone'.
     558
     559== Addendum, April 19, 2007 ==
     560
     561Updated schemas per ticket #46 (Finish documenting symbolization schema).
     562
     563== Addendum, April 24, 2007 ==
     564
     565Updated schemas per ticket #79 (Symbolization schema cleanup).
     566
     567Updated schemas per ticket #74 (Add !ExtendedData tags to symbolization schema).
     568
     569== Addendum, May 1, 2007 ==
     570
     571Updated !SymbolDefinition schema per ticket #90 (Rename Text.String element to Text.Content).
     572
     573== Addendum, May 3, 2007 ==
     574
     575Updated schemas per ticket #96 (Make version attribute fixed for new layer and symbol definition schema).
    554576
    555577== Appendix A ==
