Changes between Version 3 and Version 4 of MapGuideRfc15
02/02/07 15:38:57 (18 years ago)
robertbray
  • MapGuideRfc15
    v3 v4
    7272AJAX Viewer behavior will change slightly with this RFC. If the user selects one or more features on a layer, and then zooms out to a scale where that layer is not visible, the selected features will still be visible (even though other features on that layer are not). This is desirable because you can zoom out and then generate a large scale buffer around the selected feature(s) and immediately see the result.
    7373
    74 The NEW APIs will be documented the same way as the already existing APIs. Backwards compatibility is maintained because these are NEW APIs.
     74The NEW APIs will be documented the same way as the existing APIs. Backwards compatibility is maintained because these are NEW APIs.
    7575
    7676== Test Plan ==
