47 | | === Expose tile provider type in CREATERUNTIMEMAP/DESCRIBERUNTIMEMAP === |
48 | | |
49 | | The v3.0.0 CREATERUNTIMEMAP and DESCRIBERUNTIMEMAP schemas did not specify the underlying tile provider name when invoked on a Map Definition that links to a Tile Set Definition. Thus if CREATERUNTIMEMAP was invoked on such a Map Definition, the client does not know what type of tile provider is being used. If a Map Definition links to an XYZ tile set (which will now be a legal scenario as a result of this RFC) we need to communicate this fact back to the client so that it can properly use XYZ tile access semantics instead of normal MapGuide tile access to properly consume tiles from these base layer groups. |
50 | | |
51 | | We'll introduce a v3.3.0 RuntimeMap schema to include this information. |
52 | | |
53 | | In the Fusion viewer, if it is known that the XYZ tile provider is being used in the CREATERUNTIMEMAP response, it will create an OpenLayers.Layer.XYZ instance to read such tiles instead of the tiled version of OpenLayers.Layer.MapGuide |
54 | | |
