Changes between Version 1 and Version 2 of MapGuideRfc22
06/29/07 08:57:06 (17 years ago)
ronnielouie
  • MapGuideRfc22
    v1 v2
    2323== Overview ==
    2424
    25 This section brefly describes the problem set, and the proposed solution in general terms.  It should be deliberately short, a couple of sentences or so.
     25This RFC proposes to replace the FastCGI agent on the web-tier with an ISAPI extension and Apache module for IIS and Apache webservers respectively.
    2626
    2727== Motivation ==
    2828
    29 This is the most important part of the RFC.  It describes the problem domain in detail.  Focusing on this will allow reviewers to fully understand why the proposed change is being made, and potentially suggest different/better ways of accomplishing the desired results.  The more time we spend on understanding the problem, the better our solution will be.
     29FastCGI is a protocol for a high performance alternative to CGI for interfacing internet applications with a web server.  Current use of FastCGI has revealed some stability and performance issues relating to this technology (http://trac.osgeo.org/mapguide/ticket/129).
     30
     31The current FastCGI implementation for Microsoft Internet Information Server (IIS) was released in 2002 and has not been maintained.  IIS 7 is supposed to feature built-in FastCGI support, however it currently is in beta and should not be considered for use in a production environment.
     32
     33The Apache module for FastCGI also has not been maintained as the current implementation was released in 2003.  More recently, a binary compatible alternative FastCGI module has been developed by another third party developer to address process management issues, but it's stability and performance is rather unknown.
     34
     35By replacing the FastCGI agent with an ISAPI extension or an Apache module, the web-tier will be using more proven and stable technologies, as well as reducing the dependency on third party development to address stability and performance issues.
    3036
    3137== Proposed Solution ==
