Changes between Version 18 and Version 19 of MapGuideRfc25
08/21/07 11:31:37 (18 years ago)
rexszeto
  • MapGuideRfc25
    v18 v19
    3333== Proposed Solution ==
    3434
    35 The solution involves adding an extra "format" parameter to the selected API invocations from the Web-tier to the Server. The "format" can be either "text/xml" or "application/json". If no parameter is specified at the Web-tier, the "format" will default to "text/xml". Due to performance considerations, two additional APIs (i.e. !DescribeSchemaAsJson and GetFDOCacheInfoAsJson) have been added to handle the special cases.
     35The solution involves adding an extra "format" parameter to the selected API invocations from the Web-tier to the Server. The "format" can be either "text/xml" or "application/json". If no parameter is specified at the Web-tier, the "format" will default to "text/xml". Due to performance considerations, two additional APIs (i.e. !DescribeSchemaAsJson and GetFdoCacheInfoAsJson) have been added to handle the special cases.
    3636
    3737----
