Changes between Version 8 and Version 9 of MapGuideRfc26
08/02/07 03:11:00 (18 years ago)
yangm
  • MapGuideRfc26
    v8 v9
    1 = !MapGuide RFC 26 - Stylize Grid Surface =
     1= !MapGuide RFC 26 - Stylize Grid Surface=
    33This page contains an change request (RFC) for the !MapGuide Open Source project.
    2626== Motivation ==
    2727
    28 But for grid surface layer, such as DEM file, which would not be displayed in MapGuide as it does in Map, because the MapGuide do not have the stylization mechanism for grid surface layer as Map does. So, in this release, we will make MapGuide stylize the surface grid surface layer.
    29 If publish a grid layer to MapGuide Enterprise, the user would see Figure 1 in MapGuide Studio in the future, not the Figure 2, which is the current status for grid surface layer in MapGuide.
     28For elevation data, such as DEM file, which would not be displayed in !MapGuide as it does in Map 3D, because the !MapGuide do not have the stylization mechanism for grid surface data as Map does. So, in this release, we will make !MapGuide has the ability to stylize the elevation layer.
     29If publish a elevation layer from Map 3D to !MapGuide, the user would see Figure 1 in MapGuide Studio in the future, not the Figure 2, which is the current status for elevation data in MapGuide.
    3030
    31 ||[[Image(Before.JPG, align=center)]]||[[Image(After.JPG, align=center)]]||
    32 ||Figure1||Figure2||
     31||[[Image(After.JPG, align=center)]]|| instead of ||[[Image(Before.JPG, align=center)]]||
     32||Figure1|| ||Figure2||
    3333
    3434== Proposed Solution ==
    3838== Implications ==
    3939
    40 This section allows discussion of the repercussions of the change, such as whether there will be any breakage in backwards compatibility, if documentation will need to be updated, etc.
     40This RFC does not describe any GUI modifications. The layer definition xml document was published from Map 3D.
     41There are no changes to the existing public API.
    4142
    4243== Test Plan ==
