Changes between Version 2 and Version 3 of MapGuideRfc27
08/13/07 11:23:53 (17 years ago)
brucedechant
  • MapGuideRfc27
    v2 v3
    1919||-1||||
    2020
    21 = Overview =
     21== Overview ==
    2222
    2323This change adds a new version of the DWG Load Procedure resource schema.
    2424
    25 = Motivation =
     25== Motivation ==
    2626
    2727Autodesk !MapGuide Studio will start using a new DWG load procedure XML document.  Because the DWG load procedure document is stored in the repository the schema must be made available to the server.
    2828
    29 = Proposed Solution =
     29== Proposed Solution ==
    3030
    3131Add DWGLoadProcuedure-2.0.0.xsd to the Common/Schema folder.  this is enough to get the server to store DWG load procedures in the new format in the repository.
    117117 }}}
    118118
    119 = Implications =
     119== Implications ==
    120120
    121121None.
    122122
    123 = Test Plan =
     123== Test Plan ==
    124124
    125125There were no unit tests to test the dwg load procedure.  No new unit tests are planned.
    126126
    127 = Funding/Resources =
     127== Funding/Resources ==
    128128
    129129Supplied by Autodesk.
