Changes between Version 5 and Version 6 of MapGuideRfc29
- 08/24/07 05:05:17 (17 years ago)
MapGuideRfc29
v5 v6 88 88 * Walkway symbol RP 1 89 89 90 Here's an image showing the different behaviors for lines:91 92 [[Image(CompositeStyle.jpg)]]93 94 90 95 91 === Angular Offset Relative to Feature Geometry === … … 99 95 100 96 In the case of point features this change makes no difference - the computed angle of a point is zero. The behavior only changes for line and area features. For line features the computed angle is the angle of the polyline at the symbol insertion point. With the proposed change a user would be able to specify that his/her symbol be rotated a given amount relative to the polyline. For area features the computed angle is the angle of the longest edge. The same behavior change applies here. 97 98 Here's an image showing the different behaviors for lines: 99 100 [[Image(FromAngle.jpg)]] 101 101 102 102
