Changes between Version 1 and Version 2 of MapGuideRfc39
10/07/07 16:04:56 (17 years ago)
chrisclaydon
  • MapGuideRfc39
    v1 v2
    1 tbd
     1= !MapGuide RFC 39 - Add layer name to WMS !GetFeatureInfo response =
     7== Status ==
     8
     10||Submission Date||Oct 7, 2007||
     11||Last Modified||Chris Claydon [[Timestamp]]||
     12||Author||Chris Claydon||
     13||RFC Status||draft||
     14||Implementation Status||Not implemented||
     15||Proposed Milestone||2.0||
     16||Assigned PSC guide(s)||(when determined)||
     17||'''Voting History'''||Oct 7, 2007||
     18
     19== Overview ==
     20
     21The WMS !GetFeatureInfo request is capable of returning information for multiple features. However, it is not possible to determine which features are from which layer(s). A Trac ticket (#225) was created for this problem. This RFC contains a proposal that will allow us to return the layer name of the layer containing each of the queried features.
     23== Motivation ==
     25Applications that make use of !MapGuide's WMS support can use the !GetFeatureInfo request type to return information about features clicked on by the user. However, it is not possible to determine which layer the features come from, and this restricts the usefulness of this method.
     27== Proposed Solution ==
     28
     29The proposed solution is to add an extra property to the set of feature properties returned by the Rendering Service's !QueryFeatureProperties method. The property name will be "_MgLayerName" (which is unlikely to conflict with "real" feature property names), and the value will be the name of the layer that contains the feature.
     30
     31The web tier implementation of the WMS service will extract the layer name from this property and insert it into the WMS response.
     32
     33== Implications ==
     34
     35The response from the WMS !GetFeatureInfo request will now contain the layer name for each returned feature.
     36
     37== Test Plan ==
     38
     39The web tier test pages can be used to issue sample requests, and verify that the layer names are included in the response.
     40
     41== Funding/Resources ==
     42
     43Supplied by Autodesk.
