Changes between Version 8 and Version 9 of MapGuideRfc42
12/05/07 13:56:15 (17 years ago)
trevorwekel
  • MapGuideRfc42
    v8 v9
    6565
    6666
    67 Change the !MapGuide Server installer to ask whether the Server is being installed on the same machine as the Web Extensions.  If it is a "same machine" install, the IP address will default to localhost and the Server will not respond to a Web Extensions installed on different machine.  This configuration is better for disconnected demonstration environments (laptops).
     67Change the !MapGuide Server installer to ask whether the Server is being installed on the same machine as the Web Extensions.  If it is a "same machine" install, the IP address will default to localhost and the Server will not respond to a Web Extensions installed on different machine.  This configuration is better for disconnected demonstration environments because a routable IP address is not required.
    6868
    6969If it is not a "same machine" install, the installer will ask the user to specify the routable IP address for the Server.  This configuration is appropriate for load balanced Site Servers.
