110 | | Level 0 matches the existing functionality set without the trace log. Since code change is required, not all operations or services will support the enhanced detail. The additional detail will be implemented on an as required basis. |
| 110 | Level 0 matches the existing functionality set minus the trace log. This means no information will be written to the trace log with the default settings. To enable the trace log for a specific service, !LogsDetail should be set to level 2 or higher. |
| 111 | |
| 112 | Since code change is required, not all operations or services will support the enhanced detail. The additional detail will be implemented on an as required basis. |
