Changes between Version 4 and Version 5 of MapGuideRfc59
02/02/09 18:22:10 (16 years ago)
evan
  • MapGuideRfc59
    v4 v5
    2727
    2828== Motivation ==
    29 The existing Layer Definition XML schema does not contains a definition for TIN layer. So, currently we cannot show a real TIN surface.
     29The existing Layer Definition XML schema does not contains a definition for TIN layer. So, currently we cannot show a real TIN surface. [[BR]]
     30
    3031Adding TIN layer schema will make it easier to support TIN layer and there will be a real TIN surface. We can see points, edges and faces if we zoom into the surface.
    3132
    3334The proposed solution contains modifications to: the Layer Definition XML schema, the FDO provider, and the Stylization project.
    3435
    35 ==Layer Definition Schema Modifications==
     36==Layer Definition Schema Modifications==[[BR]]
     37
    3638TinLayerDefinitionType element was added in Layer Definition XML schema.
    3739{{{
    172174        </xs:complexType>
    173175}}}
    174 ==== !Example ===
     176==== Example ===
    175177
    176 ==! FDO Provider Modifications ==
     178== FDO Provider Modifications ==[[BR]]
     179
    177180TIN FDO Provider will be added to connect to TIN files.
    178181== Implications ==
