Changes between Version 12 and Version 13 of MapGuideRfc6
02/06/07 12:33:22 (18 years ago)
tonyfang
  • MapGuideRfc6
    v12 v13
    2525In the feature source, there is an optional tag called !SupplementalSpatialContextInfo. This can contain a !SpatialContextType defining a coordinate system override. If an entry exists for a given Spatial Context, then the specified coordinate system override will be used. The coordinate system override will be given preference over the coordinate system defined in the data.
    2626
    27 Previously, the !SupplementalSpatialContextInfo was intended for data containing spatial contexts with undefined coordinate systems. The !SupplementalSpatialContextInfo would allow a coordinate system to be specified for a given spatial context. The !SupplementalSpatialContextInfo can now be used to override coordinate systems for all spatial contexts in a feature source -- regardless of whether it contains a coordinate system or not.
     27Previously, the !SupplementalSpatialContextInfo was used only for data containing spatial contexts with undefined coordinate systems. The !SupplementalSpatialContextInfo would allow a coordinate system to be specified for a given spatial context. The !SupplementalSpatialContextInfo can now be used to override coordinate systems for all spatial contexts in a feature source -- regardless of whether it contains a coordinate system or not.
    2828
    2929== Motivation ==
