Changes between Version 18 and Version 19 of MapGuideRfc6
- 02/22/07 15:37:39 (18 years ago)
MapGuideRfc6
v18 v19 31 31 If a feature source geometry contains an incorrect coordinate system or does not have a coordinate system defined, this provides a convenient way to change the coordinate system without having to change the data of the feature source. 32 32 33 !MapGuide can only deal with spatial data . If the data does not contain a coordinate system, the data cannot be used. Changing the behaviour to allow the specification of a coordinate system override allows you to use data that you may not otherwise.33 !MapGuide can only deal with spatial data with a specified coordinate system. Changing the behaviour to allow the specification of a coordinate system override allows you to use data that you may not otherwise. 34 34 35 35 == Proposed Solution ==
