Changes between Version 19 and Version 20 of MapGuideRfc6
02/22/07 15:56:07 (18 years ago)
tonyfang
  • MapGuideRfc6
    v19 v20
    3131If a feature source geometry contains an incorrect coordinate system or does not have a coordinate system defined, this provides a convenient way to change the coordinate system without having to change the data of the feature source.
    3232
    33 !MapGuide can only deal with spatial data with a specified coordinate system. Changing the behaviour to allow the specification of a coordinate system override allows you to use data that you may not otherwise.
     33!MapGuide can only deal with spatial data with a specified coordinate system. The behaviour to allow the specification of a coordinate system override allows you to use data that you may not otherwise.
    3434
    3535== Proposed Solution ==
