Changes between Version 18 and Version 19 of MapGuideRfc77
- 07/13/09 18:35:28 (16 years ago)
MapGuideRfc77
v18 v19 304 304 This is new API only. There will be no effect on existing applications. However, API documentation need to be updated. 305 305 306 Because this API is based on FdoICreateDataStore, so it will not support creating a feature source if a file-based FDO provider doesn't support FdoICreateDataStore command. For exmaple, ORG&GDAL FDO provider will not support it even if it is a file-based provider because it doesn't support FdoICreateDataStore command. 307 306 308 Currently, there are no enough resources and funding to support creating non-file based feature sources. They may be implemented if resources and funding can be obtained in the future. 307 309
