Changes between Version 6 and Version 7 of MapGuideRfc88
- 03/22/10 22:45:10 (15 years ago)
MapGuideRfc88
v6 v7 48 48 * X and Y parameters can be specified without the SCALE parameter. The scale from the web layout will be used instead. 49 49 * BBOX is mutually exclusive to the other parameters. The BBOX parameter has precedence over the other parameters. If for some reason BBOX is specified along with X, Y and SCALE, the BBOX parameter will be accepted and the others rejected. 50 * If the BBOX parameter does not have the required number of coordinates, the default web layout settings are used. 50 51 If invalid parameter values are encountered (eg. A non-numeric X, Y, SCALE or a BBOX without 4 point values), an exception is thrown and initialization is aborted. 51 52 52 53 == Implications == … … 62 63 * Custom X, Y and Scale will start the map at the specified point and scale. 63 64 * Custom BBOX will start the map at the specified extent, regardless of whether a custom X, Y or SCALE was passed in. 64 * An invalid BBOX parameter will start the map using the default web layout values. 65 * Any other illegal combinations are ignored and will use the default web layout values. 65 * An invalid BBOX parameter or any other illegal combinations of parameters will result in a throw exception. 66 66 67 67 == Funding/Resources ==
