Changes between Version 7 and Version 8 of MapGuideRfc94
06/21/10 14:21:23 (14 years ago)
NormOlsen
  • MapGuideRfc94
    v7 v8
    1 = !MapGuide RFC 94 - Dtaum Transformation Upgrade =
     1= !MapGuide RFC 94 - Datum Transformation Upgrade =
    33This page contains an change request (RFC) for the !MapGuide Open Source project.
    99||RFC Template Version||(1.0)||
    1010||Submission Date||Wed Jun 9 16:57:56 2010 ||
    11 ||Last Modified||Norm Olsen [[Timestamp]]||
     11||Last Modified||Norm Olsen 21 June 2010||
    1212||Author||Norm Olsen||
    1313||RFC Status||draft||
    2424== Overview ==
    2525
    26 It is proposed to incorporate within the MgCoordinateSystem interface the new features of MetaCRS/CS-MAP RFC 2.  The referenced CS-MAP RFC proposes a major rework of how datum transformations are defined and is intended to improve the generality of geodetic transformations (i.e. datum shifts).
     26It is proposed to incorporate within the MgCoordinateSystem interface the new features of MetaCRS/CS-MAP RFC 2.  The referenced CS-MAP RFC 2 proposes a major rework of how datum transformations are defined and is intended to improve the generality of geodetic transformations (i.e. datum shifts).
    2727
    28 There may be few changes to existing interfaces as described below, but mostly the effort will augment (rather than change) the existing interfaces.  Numerical results produced by the proposed changes will not change, nor will the performance of the package change in either direction.  Among other things, the proposed changes will increase the number of parameters supported for a geodetic transformation, thus enabling the implementation of additional tranformation methods which could not be supported previously.
     28There may be few changes to existing interfaces as described below, but mostly the effort will augment (rather than change) the existing interfaces.  Numerical results produced by the proposed changes will not change, nor will the performance of the package change in either direction.  Among other things, the proposed changes will increase the number of parameters supported for a geodetic transformation, thus enabling the implementation of additional transformation methods which could not be supported previously.
    2929
    3030== Motivation ==
    3131
    32 CS-MAP's existing datum transformation model is an anachronism dating back to DMA TR-8350.2-B, December 1987 (TR == Technical Report). It is based on the concept of using WGS84 as what is referred to as a "pivot datum".  All geodetic transformations are defined as part of a datum definition, where the datum definition carries the method and parameters necessary to convert from the datum being defined to WGS84. A complete geodetic transformation is currently accomplished (usually) by using the forward method of the source datum to convert to WGS84 and the inverse method of the target datum to produce the desired result.
     32CS-MAP's existing datum transformation model is an anachronism dating back to DMA TR-8350.2-B, December 1987 (TR == Technical Report). It is based on the concept of using WGS84 as what is referred to as a "pivot datum".  All geodetic transformations are defined as part of a datum definition, where the datum definition carries the method and parameters necessary to convert from the datum being defined to WGS84. A complete geodetic transformation is currently accomplished (usually) by using the forward method of the source datum to convert to WGS84 and the inverse method of the target datum to produce the desired result.
    3333
    3434It is proposed that this "pivot datum" model be replaced with a model which closely resembles that used by EPSG. In this new model a geodetic transformation definition will associate a geodetic method with the appropriate parameters which will convert from a source datum to a target datum (without the implication of using WGS84 for either the source or target) and the concept of a geodetic transformation path which enable the specification of an ordered list of geodetic transformations as the means to convert from any datum to any other.  The new geodetic transformation dictionary will provide an increase in the number of transformation parameters thus enabling implementation of new transformation methods which the lack of additional parameters prohibited.
    3535
    36 The above motivations are the motivations of the referenced CS-MAP RFC #2 project.  This MapGuide RFC is proposed to enable the above defined benefits to be added to the MgCoordinateSysteme API of MapGuide.
     36The above motivations are the motivations of the referenced CS-MAP RFC 2 project.  This MapGuide RFC is proposed to enable the above defined benefits to be added to the MgCoordinateSystem API of MapGuide.
    3737
    3838== Proposed Solution ==
    4040* The reference CS-MAP RFC #2 proposes to introduce two new objects to the CS-MAP repetoire: a Geodetic Transformation object and a Geodetic Path object.
    4141
    42 * The existing MgCoordinateSystemGeodeticTransform object will be reworked to interface with this new CS-MAP equivalent and be associated with a new Geodetic Transformation Dictionary object as described below.  It is expected that the reworked interface will support all existing members of this interface; possible exceptions are linsted in the Implications section of this RFC.  As far as numeric results are concerned, the interface will not change.  There will be several additions to this interface enabling support of all transformation techniques (such as the grid file techniques).
     42* The existing MgCoordinateSystemGeodeticTransform object will be reworked to interface with this new CS-MAP equivalent and be associated with a new Geodetic Transformation Dictionary object as described below.  It is expected that the reworked interface will support all existing members of this interface; possible exceptions are listed in the Implications section of this RFC.  As far as numeric results are concerned, the interface will not change.  There will be several additions to this interface enabling support of all transformation techniques (such as the grid file techniques).
    4343
    44 * A new MapGuide object will be implemented to interface with the new CS-MAP Geodetic Path object.  This new object will be connected to a new dictionary object as detailed below.  The interface for this object will enable the specification of an order list of one or more geodetic transformations as the means by which a complete datum shift from any defined datum to any other defined datum is to be accomplished.
     44* A new MapGuide object will be implemented to interface with the new CS-MAP Geodetic Path object.  This new object will be connected to a new dictionary object as detailed below.  The interface for this object will enable the specification of an ordered list of one or more geodetic transformations as the means by which a complete datum shift from any defined datum to any other defined datum is to be accomplished.
    4545
    46 * The referenced CS-MAP RFC proposes the implementation of two entirely new dictionaries: a Geodetic Transformation Dictionary and a Geodetic Path Dictionary.  Interfaces to these new dictionaries which mimic the existing four dictionary objects would to be added to the MgCoordinateSystem interface.
     46* The referenced CS-MAP RFC 2 proposes the implementation of two entirely new dictionaries: a Geodetic Transformation Dictionary and a Geodetic Path Dictionary.  Interfaces to these new dictionaries which mimic the existing four dictionary objects would to be added to the MgCoordinateSystem interface.
    4747
    4848== Implications ==
    7474== Test Plan ==
    7575
    76 The referenced CS-MAP RFC proposes a rigorous regression test feature to insure that numerical results produced after implementation of the RFC are identical to the results produce prior to implementation of the RFC.  This same test data and algorithm will be implemented on top of the MgCoordinateSystem interface to assure that there are no regressions in the MgCoordinateSystem interface.
     76The referenced CS-MAP RFC proposes a rigorous regression test feature to insure that numerical results produced after implementation of the RFC are identical to the results produced prior to implementation of the RFC.  This same test data and algorithm will be implemented on top of the MgCoordinateSystem interface to assure that there are no regressions in the MgCoordinateSystem interface.
    7777
    7878== Funding/Resources ==
