Changes between Version 309 and Version 310 of MapGuideRfcs
- 02/05/10 09:57:04 (15 years ago)
MapGuideRfcs
v309 v310 73 73 ||[wiki:MapGuideRfc55 MapGuide RFC 55 - Switch from PROJ4 to CS-Map coordinate system library] ||implemented||2.1|| 74 74 ||[wiki:MapGuideRfc56 MapGuide RFC 56 - Add additional map commands to GETDYNAMICMAPOVERLAYIMAGE] ||implemented||2.1|| 75 ||[wiki:MapGuideRfc57 MapGuide RFC 57 - Refining the linux build process and generating install packages] ||not ready for review|| 2.2||75 ||[wiki:MapGuideRfc57 MapGuide RFC 57 - Refining the linux build process and generating install packages] ||not ready for review|| || 76 76 ||[wiki:MapGuideRfc58 MapGuide RFC 58 - Setting up a "Donate to Builds" process for the build infrastructure] || superceded ||2.1|| 77 77 ||[wiki:MapGuideRfc59 MapGuide RFC 59 - Add TIN layer type in Layer Definition Schema] ||retracted ||2.1|| 78 78 ||[wiki:MapGuideRfc60 MapGuide RFC 60 - improvement of color palette quantization for PNG8 tiles] ||implemented||2.2|| 79 79 ||[wiki:MapGuideRfc61 MapGuide RFC 61 - GetSpatialContexts cleanup] ||ready for review||2.2|| 80 ||[wiki:MapGuideRfc62 MapGuide RFC 62 - Defining consistent Structures for Mapguide and FDO Releases and Builds] || should probably be reviewed for ||2.1||81 ||[wiki:MapGuideRfc63 MapGuide RFC 63 - Introducing smart request queues to improve performance and stability] ||ready for comments|| 2.2||82 ||[wiki:MapGuideRfc64 MapGuide RFC 64 - Enabling strict exception handling for tile generation] ||ready for comments|| 2.1||83 ||[wiki:MapGuideRfc65 MapGuide RFC 65 - ACE Upgrade]|| adopted||2.2||80 ||[wiki:MapGuideRfc62 MapGuide RFC 62 - Defining consistent Structures for Mapguide and FDO Releases and Builds] ||draft|| || 81 ||[wiki:MapGuideRfc63 MapGuide RFC 63 - Introducing smart request queues to improve performance and stability] ||ready for comments|| || 82 ||[wiki:MapGuideRfc64 MapGuide RFC 64 - Enabling strict exception handling for tile generation] ||ready for comments|| || 83 ||[wiki:MapGuideRfc65 MapGuide RFC 65 - ACE Upgrade]||implemented||2.2|| 84 84 ||[wiki:MapGuideRfc66 MapGuide RFC 66 - Prevent session timeout, and give better error messages]||implemented||2.2|| 85 85 ||[wiki:MapGuideRfc67 MapGuide RFC 67 - Common Print Layout and Print Layout Elements]||adopted||2.x|| 86 ||[wiki:MapGuideRfc68 MapGuide RFC 68 - Refactoring Web .NET API into Common DLLs]|| adopted||2.2||87 ||[wiki:MapGuideRfc69 MapGuide RFC 69 - Rendering Layer Styles using Style Order]||ready for review|| 2.2||88 ||[wiki:MapGuideRfc70 MapGuide RFC 70 - Apply Schema]|| adopted||2.2||86 ||[wiki:MapGuideRfc68 MapGuide RFC 68 - Refactoring Web .NET API into Common DLLs]||implemented||2.2|| 87 ||[wiki:MapGuideRfc69 MapGuide RFC 69 - Rendering Layer Styles using Style Order]||ready for review|| || 88 ||[wiki:MapGuideRfc70 MapGuide RFC 70 - Apply Schema]||implemented||2.2|| 89 89 ||[wiki:MapGuideRfc71 MapGuide RFC 71 - AJAX Viewer Property Pane support for multiple selected features]||adopted||2.2|| 90 90 ||[wiki:MapGuideRfc72 MapGuide RFC 72 - Commercial Map Service Support]||retracted||2.2|| 91 91 ||[wiki:MapGuideRfc73 MapGuide RFC 73 - Batch Processing for layers]||implemented||2.2|| 92 92 ||[wiki:MapGuideRfc74 MapGuide RFC 74 - Move or rename resource avoid breaking links]||implemented||2.2|| 93 ||[wiki:MapGuideRfc75 MapGuide RFC 75 - Adding caching support to GETTILEIMAGE]||draft|| 2.2||94 ||[wiki:MapGuideRfc76 MapGuide RFC 76 - Grid/Graticule implementation in the MgCoordinateSystem API]|| adopted||2.2||95 ||[wiki:MapGuideRfc77 MapGuide RFC 77 - Create Feature Source]|| adopted||2.2||96 ||[wiki:MapGuideRfc78 MapGuide RFC 78 - Add transaction support to FeatureService]|| adopted||2.2||97 ||[wiki:MapGuideRfc79 MapGuide RFC 79 - Detailed Exception]|| adopted||2.2||98 ||[wiki:MapGuideRfc80 MapGuide RFC 80 - Parameter Binding]|| adopted||2.2||93 ||[wiki:MapGuideRfc75 MapGuide RFC 75 - Adding caching support to GETTILEIMAGE]||draft|| || 94 ||[wiki:MapGuideRfc76 MapGuide RFC 76 - Grid/Graticule implementation in the MgCoordinateSystem API]||implemented||2.2|| 95 ||[wiki:MapGuideRfc77 MapGuide RFC 77 - Create Feature Source]||implemented||2.2|| 96 ||[wiki:MapGuideRfc78 MapGuide RFC 78 - Add transaction support to FeatureService]||implemented||2.2|| 97 ||[wiki:MapGuideRfc79 MapGuide RFC 79 - Detailed Exception]||implemented||2.2|| 98 ||[wiki:MapGuideRfc80 MapGuide RFC 80 - Parameter Binding]||implemented||2.2|| 99 99 ||[wiki:MapGuideRfc81 MapGuide RFC 81 - Add a new widget Feature Inspector]||retracted||2.2|| 100 ||[wiki:MapGuideRfc82 MapGuide RFC 82 - Extend Reader Access by Index]|| adopted||2.2||100 ||[wiki:MapGuideRfc82 MapGuide RFC 82 - Extend Reader Access by Index]||implemented||2.2|| 101 101 ||[wiki:MapGuideRfc83 MapGuide RFC 83 - Project Sponsorship]||adopted||2.2|| 102 ||[wiki:MapGuideRfc84 MapGuide RFC 84 - Fetch Size]|| adopted||2.2||103 ||[wiki:MapGuideRfc85 MapGuide RFC 85 - Add SQLite as a load procedure type]|| adopted||2.2||102 ||[wiki:MapGuideRfc84 MapGuide RFC 84 - Fetch Size]||implemented||2.2|| 103 ||[wiki:MapGuideRfc85 MapGuide RFC 85 - Add SQLite as a load procedure type]||implemented||2.2|| 104 104 ||[wiki:MapGuideRfc86 MapGuide RFC 86 - The Pinned FDO Connection]||retracted||2.2|| 105 105 ||[wiki:MapGuideRfc87 MapGuide RFC 87 - SiteInformation enhancements]||adopted||2.2||
