Changes between Version 74 and Version 75 of MapGuideRfcs
09/06/07 10:28:33 (18 years ago)
pagameba
  • MapGuideRfcs
    v74 v75
    1414== RFCs ==
    1515
    16 ||'''Title'''||'''Status'''||
    17 ||[wiki:MapGuideRfc1 MapGuide RFC 1 - Commandline Parameter Changes]||adopted||
    18 ||[wiki:MapGuideRfc2 MapGuide RFC 2 - Unmanaged Data APIs]||adopted||
    19 ||[wiki:MapGuideRfc3 MapGuide RFC 3 - Session Affinity]||adopted||
    20 ||[wiki:MapGuideRfc4 MapGuide RFC 4 - KML Support]||as designed||
    21 ||[wiki:MapGuideRfc5 MapGuide RFC 5 - Enhanced Join Support]||adopted||
    22 ||[wiki:MapGuideRfc6 MapGuide RFC 6 - Overriding Coordinate Systems in Feature Sources]||adopted||
    23 ||[wiki:MapGuideRfc7 MapGuide RFC 7 - AJAX Tooltip Performance Optimization]||superseded ([wiki:MapGuideRfc15])||
    24 ||[wiki:MapGuideRfc8 MapGuide RFC 8 - PHP pages for describing a feature source]||adopted||
    25 ||[wiki:MapGuideRfc9 MapGuide RFC 9 - Add Convenience Methods to MgLayerBase]||adopted||
    26 ||[wiki:MapGuideRfc10 MapGuide RFC 10 - Make Schemas More Amenable to Interim Enhancements]||adopted||
    27 ||[wiki:MapGuideRfc11 MapGuide RFC 11 - Stateless Http GETTILEIMAGE request]||adopted||
    28 ||[wiki:MapGuideRfc12 MapGuide RFC 12 - Unmanaged Data API Changes]||adopted||
    29 ||[wiki:MapGuideRfc13 MapGuide RFC 13 - Configurable tile size]||adopted||
    30 ||[wiki:MapGuideRfc14 MapGuide RFC 14 - Cartographic Stylization Engine]||adopted||
    31 ||[wiki:MapGuideRfc15 MapGuide RFC 15 - New Query Features API]||adopted||
    32 ||[wiki:MapGuideRfc16 MapGuide RFC 16 - Elevation and Extrusion Support for KML]||adopted||
    33 ||[wiki:MapGuideRfc17 MapGuide RFC 17 - Map Space Line Widths]||adopted||
    34 ||[wiki:MapGuideRfc18 MapGuide RFC 18 - Localization]||adopted||
    35 ||[wiki:MapGuideRfc19 MapGuide RFC 19 - Concurrent FDO provider connections]||adopted||
     16||'''Title'''||'''Status'''||'''Version'''||
     17||[wiki:MapGuideRfc1 MapGuide RFC 1 - Commandline Parameter Changes]||implemented||1.2||
     18||[wiki:MapGuideRfc2 MapGuide RFC 2 - Unmanaged Data APIs]||implemented||1.2||
     19||[wiki:MapGuideRfc3 MapGuide RFC 3 - Session Affinity]||implemented||1.2||
     20||[wiki:MapGuideRfc4 MapGuide RFC 4 - KML Support]||as designed||1.2||
     21||[wiki:MapGuideRfc5 MapGuide RFC 5 - Enhanced Join Support]|| implemented ||1.2||
     22||[wiki:MapGuideRfc6 MapGuide RFC 6 - Overriding Coordinate Systems in Feature Sources]|| implemented ||1.2||
     23||[wiki:MapGuideRfc7 MapGuide RFC 7 - AJAX Tooltip Performance Optimization]||superseded ([wiki:MapGuideRfc15])||1.2||
     24||[wiki:MapGuideRfc8 MapGuide RFC 8 - PHP pages for describing a feature source]|| implemented ||1.2||
     25||[wiki:MapGuideRfc9 MapGuide RFC 9 - Add Convenience Methods to MgLayerBase]|| implemented ||1.2||
     26||[wiki:MapGuideRfc10 MapGuide RFC 10 - Make Schemas More Amenable to Interim Enhancements]|| implemented ||1.2||
     27||[wiki:MapGuideRfc11 MapGuide RFC 11 - Stateless Http GETTILEIMAGE request]|| implemented ||1.2||
     28||[wiki:MapGuideRfc12 MapGuide RFC 12 - Unmanaged Data API Changes]|| implemented ||1.2||
     29||[wiki:MapGuideRfc13 MapGuide RFC 13 - Configurable tile size]|| implemented ||1.2||
     30||[wiki:MapGuideRfc14 MapGuide RFC 14 - Cartographic Stylization Engine]|| implemented ||1.2||
     31||[wiki:MapGuideRfc15 MapGuide RFC 15 - New Query Features API]|| implemented ||1.2||
     32||[wiki:MapGuideRfc16 MapGuide RFC 16 - Elevation and Extrusion Support for KML]|| implemented ||1.2||
     33||[wiki:MapGuideRfc17 MapGuide RFC 17 - Map Space Line Widths]|| implemented ||1.2||
     34||[wiki:MapGuideRfc18 MapGuide RFC 18 - Localization]|| implemented ||1.2||
     35||[wiki:MapGuideRfc19 MapGuide RFC 19 - Concurrent FDO provider connections]|| implemented ||1.2||
    3636|| ||
    37 ||[wiki:MapGuideRfc20 MapGuide RFC 20 - Obtain User, Group, Role information from MapGuide session id]||draft||
    38 ||[wiki:MapGuideRfc21 MapGuide RFC 21 - Expose functionality for manipulating runtime map, using the Xml format]||draft||
    39 ||[wiki:MapGuideRfc22 MapGuide RFC 22 - Replace FastCGI]||adopted||
    40 ||[wiki:MapGuideRfc23 MapGuide RFC 23 - Berkeley DB XML 2.3 Upgrade]||adopted||
    41 ||[wiki:MapGuideRfc24 MapGuide RFC 24 - Fusion Integration]||draft||
    42 ||[wiki:MapGuideRfc25 MapGuide RFC 25 - Responses in JSON format]||draft||
    43 ||[wiki:MapGuideRfc26 MapGuide RFC 26 - Stylize Elevation Layer]||draft||
    44 ||[wiki:MapGuideRfc27 MapGuide RFC 27 - New DWG Load Procedure schema]||draft||
    45 ||[wiki:MapGuideRfc28 MapGuide RFC 28 - Web Tier APIs for Fusion support]||draft||
    46 ||[wiki:MapGuideRfc29 MapGuide RFC 29 - MDF Schema Changes for Stylization]||draft||
    47 ||[wiki:MapGuideRfc30 MapGuide RFC 30 - FDO Configuration XML Utility]||draft||
    48 ||[wiki:MapGuideRfc31 MapGuide RFC 31 - SymbolDefinition Support for Edit Controls and Rich Text Support (Markup)]||draft||
    49 ||[wiki:MapGuideRfc32 MapGuide RFC 32 - Expression Functions to Support Theming]||draft||
    50 ||[wiki:MapGuideRfc33 MapGuide RFC 33 - Convenience Methods for Selection]||draft||
     37||[wiki:MapGuideRfc20 MapGuide RFC 20 - Obtain User, Group, Role information from MapGuide session id]||draft||2.0||
     38||[wiki:MapGuideRfc21 MapGuide RFC 21 - Expose functionality for manipulating runtime map, using the Xml format]||draft||2.0||
     39||[wiki:MapGuideRfc22 MapGuide RFC 22 - Replace FastCGI]||adopted||2.0||
     40||[wiki:MapGuideRfc23 MapGuide RFC 23 - Berkeley DB XML 2.3 Upgrade]||adopted||2.0||
     41||[wiki:MapGuideRfc24 MapGuide RFC 24 - Fusion Integration]||draft||2.0||
     42||[wiki:MapGuideRfc25 MapGuide RFC 25 - Responses in JSON format]||draft||2.0||
     43||[wiki:MapGuideRfc26 MapGuide RFC 26 - Stylize Elevation Layer]||draft||2.0||
     44||[wiki:MapGuideRfc27 MapGuide RFC 27 - New DWG Load Procedure schema]||draft||2.0||
     45||[wiki:MapGuideRfc28 MapGuide RFC 28 - Web Tier APIs for Fusion support]||draft||2.0||
     46||[wiki:MapGuideRfc29 MapGuide RFC 29 - MDF Schema Changes for Stylization]||draft||2.0||
     47||[wiki:MapGuideRfc30 MapGuide RFC 30 - FDO Configuration XML Utility]||draft||2.0||
     48||[wiki:MapGuideRfc31 MapGuide RFC 31 - SymbolDefinition Support for Edit Controls and Rich Text Support (Markup)]||draft|| 2.0||
     49||[wiki:MapGuideRfc32 MapGuide RFC 32 - Expression Functions to Support Theming]||draft|| 2.0||
     50||[wiki:MapGuideRfc33 MapGuide RFC 33 - Convenience Methods for Selection]||draft||2.0||
