Changes between Version 5 and Version 6 of Release/2.4.1/Notes
- 08/16/13 00:21:26 (11 years ago)
Release/2.4.1/Notes
v5 v6 78 78 == Installer Notes == 79 79 80 * The windows installer is an '''in-place''' upgrade to MapGuide Open Source 2.4, you cannot have 2.4 and 2.4.1 installed side-by-side with the windows installer and you must uninstall 2.4 before installing 2.4.1. Use the InstantSetup bundle if side-by-side installs are required. Be sure to back up any data and applications before carrying out the new installation.80 * You cannot use the windows installer to '''in-place''' upgrade an existing MapGuide Open Source 2.4 installation, you cannot have 2.4 and 2.4.1 installed side-by-side with the windows installer and you must uninstall 2.4 before installing 2.4.1. Use the InstantSetup bundle if side-by-side installs are required. Be sure to back up any data and applications before carrying out the new installation. 81 81 * On linux, the install path is {{{/usr/local/mapguideopensource-2.4.1}}} and the FDO install path is {{{/usr/local/fdo-3.7.0}}}. You must uninstall 2.4 before installing 2.4.1. Be sure to back up any data and applications before carrying out the new installation. 82 82
