Changes between Version 4 and Version 5 of Release/2.4/Notes
- 04/18/12 06:34:38 (13 years ago)
Release/2.4/Notes
v4 v5 15 15 Windows 64 bit installer: 16 16 * [http://download.osgeo.org/mapguide/releases/2.4.0/Test/MapGuideOpenSource-2.4.0-Test-x64.exe MapGuideOpenSource-2.4.0-Test-x64.exe] 17 18 == Windows Compatibility == 19 20 ||||32-bit||64-bit|| 21 ||Windows XP SP3||Yes||Maybe*|| 22 ||Windows Server 2003||Yes||Maybe*|| 23 ||Windows Vista||Maybe+||Maybe+|| 24 ||Windows 7||Yes||Yes|| 25 ||Windows Server 2008||N/A||Yes|| 26 27 * IIS configuration will probably not work. Apache config may work due to its self-contained nature 28 29 + Not tested, but similar enough to Windows 7 to theoretically work 17 30 18 31 == Additional Post Release Patches == … … 58 71 59 72 Installing MGOS 2.4 preview alongside MGOS 2.2 or older releases is not a currently supported configuration 73 74 The installer does not currently support IIS Express as an IIS configuration option. 60 75 61 76 Please observe the updated software requirements if you are using .net and/or IIS configuration:
