Changes between Version 16 and Version 17 of Release/2.5/Notes
02/16/13 11:42:56 (12 years ago)
davidwilhelmsson
Updated wiki:ConfigureGuide24Windows description
  • Release/2.5/Notes
    v16 v17
    5151* IIS configuration will probably not work. Apache config should work due to its self-contained nature
    5252
    53 1 MapGuide 2.5.0.7349: IIS/.Net successfully tested on Windows 8 64-bit and Windows Server 2012. Windows 8 32-bit is similar enough to theoretically work. MapGuide 2.5.0.7345: IIS configuration does not work, manual configuration successfully tested ([wiki:ConfigureGuide24Windows Install MapGuide 2.4 on IIS]). Apache config untested
     531 MapGuide 2.5.0.7349: IIS/.Net successfully tested on Windows 8 64-bit and Windows Server 2012. Windows 8 32-bit is similar enough to theoretically work. MapGuide 2.5.0.7345: IIS configuration does not work, manual configuration successfully tested ([wiki:ConfigureGuide24Windows Install MapGuide 2.4/2.5 on IIS]). Apache config untested
    5454
    5555Windows RT (ie. Windows 8 on ARM devices) is not a supported platform for installing MapGuide Open Source
