Changes between Version 21 and Version 22 of Release/2.5/Notes
- 03/18/13 01:43:44 (12 years ago)
Release/2.5/Notes
v21 v22 120 120 == Known Issues == 121 121 122 * Fusion Redline widget: Cannot import/export SHP redlines on Linux due to ZipArchive support not built into our bundled PHP. 122 123 * Installer may generate a providers.xml entry for the ArcSDE provider if all providers are enabled in the "Feature Selection" dialog even if the installer does not actually bundle the ArcSDE provider. You can simply remove this entry from providers.xml after installation if this is the case. 123 124 * ~~2.4 still used as the major.minor version number in various parts of the MapGuide installation~~
