139 | 139 | Also ensure that you install the JVM of the same bitness as your installation of MapGuide. For example, you will get a {{{java.lang.UnsatisfiedLinkError}}} if you attempt to run a Tomcat from a 32-bit MapGuide installation on a 64-bit JVM. If you have both 32 and 64-bit JVMs installed, you must ensure that the Tomcat bundled with MapGuide is using the correct one. Tomcat will generally use the one indicated by the {{{JAVA_HOME}}} environment variable, so this may have to be set and/or overridden. |
