Changes between Version 4 and Version 5 of Release/2.5/Notes
01/13/13 04:14:03 (12 years ago)
jng
  • Release/2.5/Notes
    v4 v5
    11= !MapGuide 2.5 Release Notes =
     3MapGuide Open Source 2.5 Preview release is now available (for Windows only)
     5 * Milestone: [http://trac.osgeo.org/mapguide/milestone/2.5 2.5]
     6 * [http://trac.osgeo.org/mapguide/query?status=closed&group=component&resolution=fixed&milestone=2.5&order=status Resolved Tickets]
     8[[TOC]]
     10== Installation ==
     12'''NOTE: The download links below will be ready when this notice is removed'''
     13
     14Windows 32 bit installer:
     15 * [http://download.osgeo.org/mapguide/releases/2.5.0/Test/MapGuideOpenSource-2.5.0.7308-Preview-x86.exe MapGuideOpenSource-2.5.0.7308-Preview-x86.exe]
     16   * Size: 142,072,903 bytes
     17   * md5: 73c0fd393c35f15166dc6df88d5a326d
     18Windows 64 bit installer:
     19 * [http://download.osgeo.org/mapguide/releases/2.5.0/Test/MapGuideOpenSource-2.5.0.7308-Preview-x64.exe MapGuideOpenSource-2.5.0.7308-Preview-x64.exe]
     20   * Size: 147,167,422 bytes
     21   * md5: 8c1fa1dcb58603d87e3162e21b5547fe
    222
    323== Windows Compatibility ==
    1737+ Not tested, but similar enough to Windows 7 to theoretically work
    1838
    19 Windows RT is not a supported platform for installing MapGuide Open Source
     39Windows RT (ie. Windows 8 on ARM devices) is not a supported platform for installing MapGuide Open Source
    2040
    2141== Major New Items ==
    3555== FDO Compatibility ==
    3656
    37 MGOS 2.5 is compatible with FDO 3.8
     57MGOS 2.5 is compatible with FDO 3.8.
     58
     59This preview release is built against the FDO 3.8 beta 1 binary SDK.
     60
     61Key items in FDO 3.8 of benefit to MapGuide include:
     62
     63 * SQL Server provider fixes:
     64   * Flipped coordinates for geometry columns
     65   * Defects in post-insert processing, that made MgFeatureService::UpdateFeatures un-usable for SQL Server provider.
     66 * Proper intersection filter testing in ODBC provider.
     67 * GDAL raster provider with resampling support. [http://trac.osgeo.org/fdo/wiki/FDORfc65 FDO RFC 65]
    3868
    3969== Installer notes ==
    86116== API changes and notes ==#ApiChanges
    87117
     118 * The previously internal MgSelectionBase::GenerateFilters API is now available for public use
    88119 * #1012: New ExpandLayerInLegend and ExpandGroupInLegend APIs for the AJAX viewer.
    89120 * #2141: MgRenderingOptions supports a new behavior mask value (RenderBaseLayers = 8). If this value is logically OR'ed into the behavior property, the RenderDynamicOverlay API will include tiled base layers as part of the rendered image.
