Changes between Version 1 and Version 2 of Release/2.6.1/Notes
- 10/07/14 18:48:29 (10 years ago)
Release/2.6.1/Notes
v1 v2 94 94 MapGuide Open Source 2.6.1 fixes the following issues 95 95 96 * #2453: Fix missing API documentation on .net exception proxy classes. 97 * #2479: v2.6 QUERYMAPFEATURES doesn't work properly if map has no coordinate system 96 98 * #2481: RenderMap with keepSelection = true, only shows outlines of selections 99 * #2484: Base layers with labels don't render correctly 97 100 * #2485: Fix 0 line thickness causing KML lines/borders to not be drawn in Google Earth 98 101 * #2486: Use LL84 coordinate system code instead of WKT when creating MgCoordinateSystem objects for all KML operations 99 * #2484: Base layers with labels don't render correctly100 * #2479: v2.6 QUERYMAPFEATURES doesn't work properly if map has no coordinate system101 102 * #2490: Render legend image icons with transparent background 102 * #24 53: Fix missing API documentation on .net exception proxy classes.103 * #2492: Reclaim dangling sockets on mgserver restart (allows for immedate mgserver restart after crash on Linux) 103 104 104 105 == Fusion Changes/Fixes ==
