Changes between Version 2 and Version 3 of Release/2.6/Notes
- 08/24/13 09:52:38 (11 years ago)
Release/2.6/Notes
v2 v3 1 1 = !MapGuide 2.6 Release Notes = 2 3 MapGuide Open Source 2.6 Preview release is now available 2 4 3 5 * Milestone: [http://trac.osgeo.org/mapguide/milestone/2.6 2.6] … … 8 10 == Installation == 9 11 10 TBD 12 Windows 32 bit installer: 13 * [http://download.osgeo.org/mapguide/releases/2.6.0/Test/MapGuideOpenSource-2.6.0-Trunk-en-US-Release-x86.exe MapGuideOpenSource-2.6.0-Trunk-en-US-Release-x86.exe] 14 * Size: 147,016,434 bytes 15 * md5: ee8cba7acf7ba902624402e5182976de 16 Windows 64 bit installer: 17 * [http://download.osgeo.org/mapguide/releases/2.6.0/Test/MapGuideOpenSource-2.6.0-Trunk-en-US-Release64-x64.exe MapGuideOpenSource-2.6.0-Trunk-en-US-Release64-x64] 18 * Size: 152,732,183 bytes 19 * md5: 0282d10b792ad62633ce201053f58138 11 20 12 21 == Windows Compatibility == … … 77 86 78 87 * #2252: It is not possible to call MgFeatureService::UpdateFeatures() with a NULL MgTransaction in the PHP API 88 * x86 installer may not install the Visual C++ 2008 runtime library properly 79 89 * Installer may generate a providers.xml entry for the ArcSDE provider if all providers are enabled in the "Feature Selection" dialog even if the installer does not actually bundle the ArcSDE provider. You can simply remove this entry from providers.xml after installation if this is the case. 80 90 * Ubuntu: Failure to install some pre-requisite packages may derail the install script. You may need to update your apt package database (apt-get update) before running the install script
