Changes between Version 12 and Version 13 of Release/3.0/Notes
- 03/31/15 04:57:20 (10 years ago)
Release/3.0/Notes
v12 v13 137 137 === Changes from Preview Release 1 === 138 138 139 * #2550: RFC 140 Errata: The coordinate system of XYZ tile sets has been changed from {{{LL84}}} to {{{WGS84.PseudoMercator}}}. The result of this change is improved image quality of rendered XYZ tiles. This has no effect on public APIs. If you have already cached XYZ tiles from a PR1 installation, you should re-seed that tile cache.139 * #2550: RFC 140 Errata: The coordinate system of XYZ tile sets has been changed from {{{LL84}}} to {{{WGS84.PseudoMercator}}}. The result of this change is improved image quality of rendered XYZ tiles. This has no effect on public APIs. If you have already cached XYZ tiles from a PR1 installation, you should clear and re-seed that tile cache. 140 140 * #2524, #2534: Improved error message quality 141 141 * #2530: Added limited support for ordered query results from SDF/SHP providers
