Changes between Version 13 and Version 14 of Release/3.1/Notes
- 07/27/16 07:20:38 (8 years ago)
Release/3.1/Notes
v13 v14 220 220 Note that upgrading Apache from 2.2.x to 2.4.x has introduced changes to some configuration directives. If you have any custom httpd directives defined in your current MapGuide installation, please consult the [https://httpd.apache.org/docs/2.4/upgrading.html upgrade notes] for any changes you have to do when migrating/upgrading your Apache-based MapGuide installation to this release. 221 221 222 If you have PHP-based MapGuide applications, consult the [http://php.net/manual/en/migration54.php 5.3 to 5.4 migration guide] and [http://php.net/manual/en/migration55.php 5.4 to 5.5migration guide] for any API and compatibility issues that may be present in your MapGuide application as a result of moving to PHP 5.5222 If you have PHP-based MapGuide applications, consult the [http://php.net/manual/en/migration54.php 5.3 to 5.4 migration guide],[http://php.net/manual/en/migration55.php 5.4 to 5.5 migration guide] and [http://php.net/manual/en/migration56.php 5.5 to 5.6 migration guide] for any API and compatibility issues that may be present in your MapGuide application as a result of moving to PHP 5.5 223 223 224 224 Should you choose to uninstall the Linux build of this release at any time, download and the respective uninstaller script. This ensures that any proper service un-registration is also performed.
