Changes between Version 15 and Version 16 of Release/3.1/Notes
07/27/16 07:23:40 (8 years ago)
jng
  • Release/3.1/Notes
    v15 v16
    235235 * Fusion: Geolocation widget will no longer work on Chrome 50+ on insecure origins (https://developers.google.com/web/updates/2016/04/geolocation-on-secure-contexts-only?hl=en). Solution: Host the fusion application on a site over HTTPS.
    236236 * Fusion: Google Street View may not load properly in Chrome (https://productforums.google.com/forum/#!topic/maps/7DiQ4FQj8ts). Workaround: Disable "Accelerated 2D canvas" in chrome flags settings.
    237  * On Ubuntu, bash needs to be the default shell due to bash-isms in the service control scripts (#2497)
    238237 * Installing msttcorefonts for your specific distro is strongly recommended to avoid the case of "hieroglyphic" labels. You can specify the path of your msttcorefonts installation in serverconfig.ini to have MapGuide load these fonts in on startup.
    239238 * Using the Linux builds of MapGuide on distributions they were not built for is not supported. If you want to run MapGuide on:
