Changes between Version 8 and Version 9 of Release/3.1/Notes
- 05/27/16 04:57:30 (9 years ago)
Release/3.1/Notes
v8 v9 204 204 205 205 Then consider running MapGuide in a [https://www.docker.com/ docker container] that is based on Ubuntu 12.04 or CentOS 6.x. This installation method is not supported and is only mentioned here for informational purposes. 206 * The 64-bit builds of MapGuide are made available for testing/feedback.206 * The 64-bit Linux builds of MapGuide are made available for testing/feedback. These builds should be considered experimental. 207 207 * The following FDO providers may or may not not be functional in 64-bit Linux builds of MapGuide 208 208 * SHP (spatial indexing code not working properly in 64-bit, will cause incorrect spatial queries. Workaround: Use OGR provider)
