Changes between Version 3 and Version 4 of TicketQuery
- 09/05/24 03:39:36 (5 months ago)
TicketQuery
v3 v4 151 151 === Format: table 152 152 153 You can choose the columns displayed in the table format (`format=table`) using `col=<field>`. You can specify multiple fields and the order they are displayed by placing pipes (`|`) between the columns:153 You can choose the columns displayed in the table format (`format=table`) using `col=<field>`. You can specify multiple fields and the order they are displayed in by placing pipes (`|`) between the columns: 154 154 {{{ 155 155 [[TicketQuery(max=3,status=closed,order=id,desc=1,format=table,col=resolution|summary|owner|reporter)]]
