Changes between Version 3 and Version 4 of TracWiki
02/01/17 00:38:00 (8 years ago)
  • TracWiki
    v3 v4
    22[[TracGuideToc]]
    4 Trac has a built-in wiki system which you can use for organizing knowledge and information in a very flexible way by [WikiNewPage creating pages] containing an intuitive and easy to learn textual markup. This text markup is also used in all other parts of the system, not only in [wiki:TitleIndex wiki pages], but also in [wiki:TracTickets ticket] description and comments, [wiki:TracChangeset check-in log messages], [wiki:TracRoadmap milestone] descriptions and [wiki:TracReports report] descriptions, even in third-party extensions.
     4Trac has a built-in wiki system which you can use for organizing knowledge and information in a very flexible way by [WikiNewPage creating pages] containing an intuitive and easy to learn textual markup. The wiki markup is used throughout Trac, so not only in [wiki:TitleIndex wiki pages], but also in [TracTickets ticket] description and comments, [TracChangeset version control] log messages, [TracRoadmap milestone] descriptions, [TracReports report] descriptions  and even in third-party extensions.
    55It allows for formatted text and hyperlinks in and between all Trac modules.
    66
    7 Editing wiki text is easy, using any web browser and a simple [WikiFormatting formatting system], rather than more complex markup languages like HTML.  The reasoning behind its design is that HTML, with its large collection of nestable tags, is too complicated to allow fast-paced editing, and distracts from the actual content of the pages. Note though that Trac also supports [WikiHtml HTML], [WikiRestructuredText reStructuredText] and [http://www.textism.com/tools/textile/ Textile] as alternative markup formats, which can eventually be used in parts of a page (so called wiki “blocks”).
     7Editing wiki text is easy, as compared to complex markup languages like HTML, using any web browser and simple [WikiFormatting formatting]. The motivation for wiki markup is that HTML, with its large collection of nestable tags, is too complicated to allow fast-paced editing, and distracts from the actual content of the pages. Note that Trac also supports [WikiHtml HTML], [WikiRestructuredText reStructuredText] and [https://txstyle.org Textile] as alternative markup formats, which can be used in parts of a page, so called wiki blocks.
    88
    9 The main goal of the wiki is to make editing text easier and ''encourage'' people to contribute and annotate text content for a project. Trac also provides a simple toolbar to make formatting text even easier, and supports the [http://universaleditbutton.org/Universal_Edit_Button universal edit button] of your browser.
     9The main goal of the wiki is to make editing text easy in order to ''encourage'' people to contribute to a project. Trac also provides a simple toolbar to make formatting text even easier, and supports the [http://universaleditbutton.org/Universal_Edit_Button universal edit button] of your browser.
    1010
    1111The wiki itself does not enforce any structure, but rather resembles a stack of empty sheets of paper, where you can organize information and documentation as you see fit, and later reorganize if necessary.
    12 As contributing to a wiki is essentially building hypertext,
    13 general advice regarding HTML authoring apply here as well.
    14 For example, the ''[http://www.w3.org/Provider/Style Style Guide for online hypertext]'' explains how to think about the
    15 [http://www.w3.org/Provider/Style/Structure.html overall structure of a work]
    16 and how to organize information [http://www.w3.org/Provider/Style/WithinDocument.html within each document]. One of the most important tips is “make your HTML page such that you can read it even if you don't follow any links.”
     12As contributing to a wiki is essentially building hypertext, general advice regarding HTML authoring apply here as well.
     13For example, the ''[https://www.w3.org/Provider/Style Style Guide for online hypertext]'' explains how to think about the [https://www.w3.org/Provider/Style/Structure.html overall structure of a work] and how to organize information [https://www.w3.org/Provider/Style/WithinDocument.html within each document]. One of the most important tips is to "make your HTML page such that you can read it, even if you don't follow any links".
    1714
    1815Learn more about:
    19  * WikiFormatting rules, including advanced topics like WikiMacros and WikiProcessors
    20  * How to use WikiPageNames and other forms of TracLinks which are used to refer in a precise way to any resource within Trac
     16 * WikiFormatting rules, including advanced topics like WikiMacros and WikiProcessors.
     17 * How to use WikiPageNames and other forms of TracLinks which are used to refer to any resource within Trac.
    2118
    22 If you want to practice editing, please use the SandBox. Note that not all Trac wikis are editable by anyone, this depends on the local policy; check with your Trac administrators.
     19If you want to practice editing, please use the SandBox. Note that not all Trac wiki pages are editable by anyone, this depends on the local policy; check with your Trac administrators.
    2320
    24 Before saving your changes, you can ''Preview'' the page or ''Review the Changes'' you've made.
    25 You can get an automatic preview of the formatting as you type when you activate the ''Edit Side-by-side'' mode (you have to Preview the page for the setting to take effect). '' There is a [wiki:/TracIni#trac-section configurable delay] between when you make your edit and when the automatic preview will update.''
     21Before saving your changes, you can ''Preview'' the page or ''Review Changes'' you have made.
     22You can get an automatic preview of the formatting as you type when you activate the ''Edit Side-by-side'' mode. There is a [wiki:TracIni#/auto_preview_timeout configurable delay] between when you make your edit and when the automatic preview will update.
    2623
    2724Some more information about wikis on the web:
    28  * A definition of [http://wikipedia.org/wiki/Wiki Wiki], in a famous wiki encyclopedia
    29  * The [http://c2.com/cgi/wiki?WikiHistory History] of the original wiki
    30  * A wiki page explaining [http://www.usemod.com/cgi-bin/mb.pl?WhyWikiWorks why wiki works]
     25 * A definition of [https://wikipedia.org/wiki/Wiki Wiki] according to Wikipedia.
     26 * The [http://c2.com/cgi/wiki?WikiHistory history] behind the original wiki.
     27 * A wiki page explaining [http://www.usemod.com/cgi-bin/mb.pl?WhyWikiWorks why wiki works].
    3128
    3229----
