Changes between Version 109 and Version 110 of maestro/Downloads
07/21/13 10:51:03 (12 years ago)
jng
  • maestro/Downloads
    v109 v110
    66== Preview release ==
    8 The current preview release of MapGuide Maestro is '''5.0 RC2 (5.0.0.7653)'''
     8There are currently no preview releases available
     10== Stable release ==
     12The current stable release of MapGuide Maestro is '''5.0.0 (5.0.0.7698)'''
    913
    1014=== Windows ===
    1216On windows you can download MapGuide Maestro as a NSIS installer package, or as a zipped file of executeables. You must have the '''.Net framework 4.0''' installed. The installer will automatically ask you to install it, if you don't have it.
    1317
    14  *  '''[http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-Release-5.0RC2-Setup.exe Installer (recommended)]'''
    15  *  [http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-5.0RC2-Release.zip Binaries]
     18 *  '''[http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-Release-5.0.0-Setup.exe Installer (recommended)]'''
     19 *  [http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-5.0.0-Release.zip Binaries]
    1620
    1721=== Linux / Mac OS ===
    2125For linux or Mac OS, you must first install [http://www.mono-project.com/Main_Page Mono] and the winforms packages. Once Mono is installed, please download the binaries:
    2226
    23  *  [http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-5.0RC2-Release.zip Binaries]
     27 *  [http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-5.0.0-Release.zip Binaries]
    2428
    2529Please note for '''5.0 beta 1''' onwards, the minimum required version of Mono is '''2.8'''
    3741 * A Visual Studio 2010 solution of .net console/desktop sample projects illustrating use of the Maestro API
    3842 * A Visual Studio 2010 solution of ASP.net sample projects illustration use of the Maestro API in a web context
     43 * A ProviderTemplate utility that generates and compiles a Maestro.LocalNative provider targeted towards your specific version of the MapGuide API
    3944 * Maestro API documentation in Compiled HTML Help (CHM) format.
    4045
    4348SDK packages are released concurrently with Maestro. Whenever a new release of Maestro is available, you can expect a new SDK release as well.
    4449
    45 [http://download.osgeo.org/mapguide/maestro/MaestroSDK_5.0RC2.zip Download]
     50[http://download.osgeo.org/mapguide/maestro/MaestroSDK_5.0.0.zip Download]
    4651
    47 == Stable release ==
     52== 4.0.x Maintenance release ==
    4853
    49 The current stable release of MapGuide Maestro is '''4.0.5 (4.0.5.7527)'''
     54The current 4.0.x maintenance release of MapGuide Maestro is '''4.0.6 (4.0.6.7687)'''
    5055
    5156=== Windows ===
    5358On windows you can download !MapGuide Maestro as a NSIS installer package, or as a zipped file of executeables.
    5459You must have the '''.Net framework 2.0''' installed. The installer will automatically ask you to install it, if you don't have it.
    55  *  '''[http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-Release-4.0.5-Setup.exe Installer (recommended)]'''
    56  *  [http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-4.0.5-Release.zip Binaries]
     60 *  '''[http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-Release-4.0.6-Setup.exe Installer (recommended)]'''
     61 *  [http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-4.0.6-Release.zip Binaries]
    5762
    5863=== Linux / Mac OS ===
    6267For linux or Mac OS, you must first install [http://www.mono-project.com/Main_Page Mono] and the winforms packages.
    6368Once Mono is installed, please download the binaries:
    64  *  '''[http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-4.0.5-Release.zip Binaries]'''
     69 *  '''[http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-4.0.6-Release.zip Binaries]'''
    6570
    6671The installation is simply unzipping the file:
    6772{{{
    68 unzip "MapGuideMaestro-4.0.5-Release.zip"
     73unzip "MapGuideMaestro-4.0.6-Release.zip"
    6974}}}
    7075Then run the application:
    101106SDK packages are released concurrently with Maestro. Whenever a new release of Maestro is available, you can expect a new SDK release as well.
    102107
    103 [http://download.osgeo.org/mapguide/maestro/MaestroSDK_4.0.5.zip Download]
     108[http://download.osgeo.org/mapguide/maestro/MaestroSDK_4.0.6.zip Download]
    104109
    105110== Previous releases ==
