Changes between Version 16 and Version 17 of maestro/Downloads
08/23/08 03:25:59 (16 years ago)
ksgeograf
  • maestro/Downloads
    v16 v17
    3939== Preview releases ==
    4040This releases may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there.
    41  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3270.msi Installer r3270]
    42  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3270.zip Binaries r3270]
     41 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3285.msi Installer r3285]
     42 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3285.zip Binaries r3285]
    4343The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code.
    4444
    45 r3270 has the following fixes and additions to 1.0.8:
     45r3285 has the following fixes and additions to 1.0.8:
    4646 *  Fixed a bug if the username is "Administrator" and the password is "admin", the OK button would be disabled
    4747 *  Fixed a bug with building Gdal composite data config files
    4848 *  Fixed a folder case problem (bug on Linux only)
    4949 *  Added a menu to create and restore packages (MGP files) directly from Maestro
     50 *  Added a menu to edit packages
     51 *  Fixed an issue with character encoding of featuresources on layers
    5052
    5153== Previous releases ==
